Sorry Tom for ignoring your MT03 work :innocent:
From the beginning Iâm not at all into the Haiklite flashlights (donât like the chunky designs), but considering that it is a rather new brand and seems to be founded by enthousiastic and knowledgable people, it is a pity that they do not have their production method and QC under control. Among the other faults, a ledboard that is not flat on its shelf is an easily avoidable (flattening the shelf should be the very last machining step) and unforgivable blunder because it directly affects the performance in such a high powered light.
XHP70.2âs with that driver is a great update! Waiting for finish and numbers
I've been disappointed with the QC as well coming from them, but I'm lik'n the chunky design more and more. Mass and surface area are the two big issues with high amps, so they got the mass part down pat, as long as I can fix up the other stuff . I have 2 other Haikelite on order, the TK35 and SC01, and planning on getting the MT07S.
What I like bout what I'm seeing is easy modding - nice driver retaining rings, standard size drivers in width and thickness, easy modding for the LED's and battery setups, etc.
Made some SST40 led testing so I ended up with a Convoy C8 with TA17 driver, SST40 N4 BA dedomed led, AR coated glass lens, bypassed springs, 8,6A current in turbo, 2000 lumens, 136 Kcd and 738m throw In a C8 it is insane!
I got 3 of those on the way from KD. Those are pretty nice #'s, specially the lumens for a dedomed LED that throws almost as good as the best dedomed XP-G2's, I think. Didn't know you can get that many amps out of one. Might just put them in a SRK. What do you think of the tint after dedoming, and the beam pattern?
Hhmm, for that price, might order a bunch more.
Ohhh - and these are "only" N4 bins. There's 2 higher bins listed in the specs, but who knows if they will ever happen (N5 and P2).
Upside down on some wires in regular 95 octane petrol. It took 3-4 hours and a bit of picking with a needle and falled down. After that cleaning with alcohol rinse and a needle under magnifying glass.
First attempt at XHP Soup, HOT fluid de-doming (tried 2 different fluids, the second fluid performed better) XHP35âs 50âs and 70âs all meat no veggies!
Brand New $8.00 Garage Sale Crock pot, so far soooooo gooooood!
I made sort of a cooperative multitasking toolkit with event callbacks and a finite state machine, to make it easier to create e-switch light UIs.
It works on tiny45 and tiny85, and it should be reasonably easy to add support for other MCUs later. Most of the hardware details are abstracted out to allow interfaces to be portable across different types of drivers.
I may have also just cloned ZebraLightâs UI in the time between my previous two comments.
I call it DarkHorse.
It doesnât have memory which lasts across battery changes yet, but thatâs next on the list. I just need to make an API for eeprom accessâŚ
At some later point I might make an improved version and call it DarkerHorse. But for now the only improvement is replacing â6+ double clicks to configure secondary levelâ with âclick then hold to configure secondary levelâ. It was a bit ridiculous having to click 16 times to switch between 10 lm and 34 lm.
Waiting for TK to develop the perfect UI, itâll be called Major Deity, weâll know it as Perfection 101. Sheâll have it read our mind through our retina, a simple stare into the lens and itâll KNOW what we want from the UI and respond accordingly. Then the switch will be a fingerprint reader in the battery tube, contact with our hand will allow the light to AUTOMATICALLY turn on/off and adjust level according to our thoughtsâŚ
