I have an Astrolux SC that really like but was not using it because is to heavy for my taste, so modded with a xhp-70.2 NW from KD, a MTN Fet driver and two windyfire 14500 IMR.
Cut the threads from the tailcap and soldered two pieces of copper plumbing tube. Inner/outer diamenter and lenth are perfect fit, just plug and solder.
8.7A startup and 3.4A at 30sec nearly burning hot.
Soldering: phone camera show pink but it was really red.
Dale, can you please tell the diameter of the LED plate? Or, if you canāt say that, can you tell me what diameter the flashlight take (14mm or 16 mm)?
Thank you in advance
I think it was a 14mm MCPCB, Iāll measure it here directly and let you know. Took a good bit of filing on a 16mm Noctigon. Had to thin the Noctigon down some too.
Nice work Steel! Sweet pics too, thanks for sharing!
At least it has a chunk of heat sink thatās one piece, so maybe it did need a little tightening up, fairly easily corrected it looks like and now itās a very sweet light, good job all around!
Calling all cars! Or tinkerers. I have a gutted novatac Wichita that I want to become a Flashlight again. It needs the driver, led, reflector and lens. Wondering who has the time they can undertake this project for me in the USA. My screen name at aol is my address if you want pics of the light from me.
The tail switch is intact and I donāt expect you to work for free. I prefer to put a nw led. I would love to have a photo red in it. If you can put a triple in there with a secondary red led running a ramping driver, Iād be ecstatic!!! You can skip the alligator grips, Swarovski button, and tri-color gold lanyard. Pm me for suggestions
Modded a Sipik 98. Replaced the driver with a DrJones H17F. Replaced emitter with a dedomed SST40 on copper Noctigon.
I donāt have any Toluene so dedomed the emitter by slicing it with an x-acto knife while the LED was just below reflow temperature. The driver space in the pill fit a 20mm driver. Fortunately I had a brass 17mmā>20mm driver adaptor ring from Mountain Electronics on hand.
The light has a hollow pill. I didnāt build a heatsink to put under the pill, but I was very generous in applying Arctic Silver 5 to the edges. of the star.
Light works perfectly. Itās bulkier than my other zoomies, but also much brighter and throwier.
Iām undecided if I want to further mod this light. Additional mods Iām considering:
Shorten the light - easiest way is to reduce the length of the pill, back of the head, or the heat sink fins. Thereās a lot of empty space in the pill that could be salvaged. Might be able to reduce the length of the light 1 cm.
mod tailcap to make it illuminated.
apply sideswitch mod like I did with the smaller Aleto N8 a few years ago. The sideswitch mod is fairly difficult, but applying it would allow me to take another cm off the length of the light and switch the UI to the D4 UI.
I waved my magic Grizzly at a bar of aluminum and turned itās heart into gold. Er, well, copper anyway.
The copper pill is 35mm diameter and 35mm deep, with the top 10mm smooth and mated to the aluminum battery tube, the lower 25mm is threaded at 0.75mm thread pitch and has a driver bay cut in. This will be DBC-06.
Thanks robo, the tube is bored for a single 32650 due to itās 6000mAh capacity. I have the reflector out of my Olight SR-90 Intimidator and am working out how to mount it, so Iām going for a thrower hereā¦ when I first got the Intimidator I had it doing 665Kcd in the big light with a de-domed XM-L2, so Iām hoping with the better emitters out today I can hit a mile. Thatās the project goal anyway.
Iāve got a big 4 1/4ā diameter chunk of 6061 in the chuck of the lathe and need to get back out there spinning it upā¦
Edit: Will try to remember to shoot a pic of this massive hunk of aluminum in the 5ā jaws, before my hands get all oily and dirty.
