Yes the MCPCB is DTP. It wasnāt the first time I removed the bezel and in the led solder I found some air bobbles so it was not perfect.
My stock numbers:
2,2A at battery
897 lumens
74800 cd
After R100 resistor mod I got these numbers:
3,65A at battery
1250 lumens
103000 cd
You can see my google tables with beamshots and compare a lot of other lights.
:heart_eyes: that test board, with the little styrofoam ball to diffuse the led :party:
(it is how I made my first, and last, working radio back in the seventies, with a simple ferrite rod AM receiver and two-step amplifier . After condensing the circuit on a proper circuit board I never got it to work again).
Great that you got the flashing stuff to work. When I retire in 17 years from now and have all the time in the world just before I die, I will pick up these skills as well.
Worked on the UT02 6500K today.
20AWG wires and bypassed springs. R100 resistor mod and polished the SW cover after it got scratched taking it apart. SW also wasnāt very smooth but it is now.
Impressive light for $30. I liked seeing the Genuine TP5000 chip on the charge board. Nicely made over all too. Killer pencil beam and I am pretty happy with what they call 6500K, no blue IMO. I got 3.78A at the tail on DMM.
Zero back feed to the charge port so I am going to integrate a magnetic port adapter like my M3 Clone.
The EC21 that I got open yesterday, tonight has received a Nichia 219C R9050 sm4070e led. The output did not even really suffer from it, measured at 30 seconds, the output went from 445 lumen to 375 lumen. So just a 15% loss for a dramatic tint and colour rendering improvement. (But the EC21 was never about output anyway, but about usefulness and runtime).
This is my first mod with this exclusive led (just a handful 219Cās in this specific tint area were obtained and sold by clemence) and it is different than I expected. I expected a quite rosy tint on top of the slight yellow-ness that 4000K leds have, instead it is less yellow than my 4000K R9080 E2L mod, and not rosy at all, it looks very neutral white to me.
(it may be this particular led, the sm4070e tint covers a fairly large area , although it is all under the BBL, but this led may just be close to it)
All in all, a super nice neutral tint
( ^ this pic suggests a load of red but the camera did not pick up the real tint very well. Btw, even the camera sees absolutely no PWM)
Got the New Convoy S9 today.
Just had to take it apart. Didnāt even turn it on before hand.
Aluminum MCPCB so it got an XM Noctigon. And had cheesy wires that melted while desoldering so it got 22AWG silicone from the scrap pile.
I measured 1.9A at the tail, higher than rated.
Here is a pic of the driver. Could it be resistor modded?
That SW cover had a nasty coating on it. Not just the Anno. Stripped the anno in Lye. Tried sanding it with 400 and gave up. Started lightly filing it down to raw metal and continued sanding getting up to 2000 grit. Used Mothers aluminum polish on a paper towel.
Originally the button had a nasty chrunch while pushing and felt bad. Its nice and smooth now.
Yeah I was thinking that but I do not know enough. It is 0805 size and the pads and easily do 1206. I had not measured it before taking apart so I didnāt want to add another before knowing. I have some 1206 R050 on the way and have 1206 R100 on hand. Will wait for the other R050 to arrive for easier stack.
Didnāt separate the boards either. Will try on the next go and get some pics. I kinda think all charge is below.
Looks like the S9 was in a giving mood.
Put an R100 on top of the R050 and I get 2.7A at the tail on my DMM.
At 2.7A the light now get s hot with the Noctigon MCPCB. No step down. Holding it in bare hand seems to sink enough heat but standing alone it will get hot and the heat will travel down the tube heating the battery.
It appears to me the charge is all on the lower board with the E-SW.
I separated the two and there is another pair of indicator LEDs under the top driver board that turn on blue with light and the second red LED shows low voltage.
The three pins are, Pin closest to SW (Left) is the SW signal, Middle is Pos and the Right would be Neg.
With the boards separated and a 5V power to the micro USB the blue lights and there is a faint flash of the red as it hunts for something to charge.
Best I can explain itā¦.
Lower Charge board
Top driver board and resistor mod. Also Bottom of the driver board with indicator pair of LEDs.
All my gear is put up for family visiting during Christmas, but I still managed to fit an UCLp lens to a new Red Sofirn SP10B with side switch. Very neat little 14500 light with 4 modes, gained 68 lumens for a simple lens fitment. Took it from 590 lumens to 659.
Amazon delivered it overnight, on Sunday, even Christmas Eve! Sweet work on Amazonās part and whoever delivered itā¦. :+1:
Sofirn is doing some excellent work these days, loving their offeringsā¦
Will be doing a review on their new SP32A tomorrowā¦ (big brother to this little 14500 light)
