I tend to notice within minutes. It causes some battery drain but not enough to impact reliability. It’s annoyance and nothing more than that. At this frequency - a manageable one. Again, that’s only my case.
Boruit RJ-02 has some kind of a clicky e-switch. YLP F15 Falcon as well.
But I don’t remember the details of their actuation.
Did the o-ring mod to both my FWAAs and now the switch is much stiffer. Zero accidental activations since doing that.
However, I still think accidental pocket activation, while unlikely, would eventually happen if I carried it in my pocket with my keys long enough.
There’s no chance of pocket roasting, since I set the max ramp below what is necessary to burn my pocket. However, an accidental activation that gets to max ramp might still drain the battery.
I’ve had numerous FWXX models of lights and carry them constantly, never once have I had an accidental activation. I always use the electronic lockout though. I will say one click for on is much easier than four but even then it takes me less than 2 seconds to turn on with the electronic lockout. To me that’s acceptable to not have my pocket/leg burned lol.
It is how I use my EDC, I’m getting older and my eyes get worse, I use my light to light something up multiple times a day, usually a few seconds at a time. From need to actual light is a second or 2. Any lockout action would not work for me.
I put quad Nichia E17A SM503-B12-R9080 5000K LEDs into a Convoy M1. I frosted the lens in order to eliminate the donut hole and installed a Convoy driver (and put it to mode group 8 to keep the current to less than 4 amps). I also made a custom turquoise lighted switch that uses 0.15 milliamps.
It has some throw (due to the deep OP reflector) and excellent tint.
A very nice mod! That has become a beautiful light. :+1:
What about the double tail-leds?, do they have a different colour that is mixed? Camera’s are very bad in picking up monochrome colours accurately.
Not really a mod, but i made a box for my integrating sphere.
I’m no Carpenter, so it took me quite some time and effort, but i think its not a bad job for an amateur.
(It needs some finishing)
It needed a sturdy box since i was using an old Cardboard box, but my wife thought it was part of the pile with old paper, so she placed some boxes with old magazines on top, the sphere survived, the Cardboard box not.
The “Disinfector” is complete. 3x Klaran UV-C totaling over 200mW of disinfecting power! Sneak peak of what I’m making next in the background
Driver is a H2-C but I’m really not happy with it. For whatever reason it keeps blinking shortly after the light is turned on. This is apparently to indicate low voltage. However, it does the same thing on a freshly charged 21700…
Have you thought about grinding down the inside of the driver retaining ring? Looks like a couple of chips may be getting in the way of making a good connection:
Great catch! Drilled it out today. I tried various different fully charged 18650s and even 2x 18350s but unfortunately it still blinks. Defective driver I’m guessing. Will see if there are alternatives.
An early version D25A Ti with FET driver cannot handle turbo mode for more than a couple minutes when equipped with an LH351D and a FET driver and running on a Vapcell H10.
Head overheated and light disabled itself. Fortunately, a driver wire disconnected from the star and cut the circuit.
Unfortunately, when things shifted as it overheated, a bit of the slightly too small plastic centering ring cut into the LED dome. I tried shaving the dome afterwards but cut too close and removed some of the phosphor. That led is destroyed.
A tiny titanium head just isn’t good for heatsinking even with the LED sitting on a copper Noctigon.
Replaced the LED with a different one and now it works fine again. But perhaps H10 isn’t the proper cell for this light.
