Whoops! No I didn’t realize that. None of the posts I looked at on how to disassemble the light mentioned that. :confounded: Or if they did I missed it.
Unfortunately, my misguided attempts to modify the light appears to have destroyed it. :weary:
I reassembled it, but now the light doesn’t work properly. It doesn’t turn off. Pressing the switch causes the light to turn off only while the button is held down. And while holding it down I can see it cycle through the modes, but the moment I release the button, the light goes back to max power.
I don’t think I’m going to attempt to modify a Zebralight ever again.
I can’t even take a close look at the driver to see if maybe something got shorted or dislodged, since I can’t remove the PCB.
EDIT:
I opened it up again to attempt to remove the positive wire. But how do I do that?
The tip of the wire passes through a hole below the left screw. The hole is completely filled with solder, which I can’t remove. My solder sucker isn’t long enough and doesn’t have enough suction. Also, even when I keep that solder liquid by keeping the tip of my iron in it, the driver still does not move at all when I insert a pick into the screw holes and try to pry it up.
I need more detailed instructions on how to remove an SC52 driver. The existing pictures on the internet are not sufficient.
I never opened a SC62, usually there is no solder in the plated through hole and the wire is soldered to a pad next to it, but in the case of the hole filled with solder ( e.g. in the SC700 there is no pad, instead of a wire it’s a solid pin soldered to the through hole) then you need to do as you did, pull on the driver while melting the solder, add a lower temp solder (ZL use lead free solder) so that it melts more easily.
And as I mentionned it’s easier to pull with screws to grab on :
Thanks jon_slider , I’m sorry if the photos is too much . Yeah, but I still don’t know what Pebble TIR that would fitted well. Also, what degrees would be match between throw and flood? I don’t have any experience with Pebble TIR before, any idea?
WARNING:
What you’re about to see is pure bastardization and flashlight modding blasphemy
First there was this
(well, it misses a triple DTP MCPCB with Nichia 219c 5000K 70CRI and a triple TIR optic :zipper_mouth_face: You can find them here :D)
Then, there was this
And in the end…there was this
I’ll tell you what I did! I did what could be considered a “bastardized” FW1AA!
Why bastardized? Because it doesn’t have Anduril It could have it, but… it wouldn’t be the same
So, what does it have?
bezel, head, the screw on the shelf, driver retaining ring, tube, tail, and inner o-rings from the FWAA
TIR optic from a deceased Olight S1R Baton
DTP MCPCB from a the Eagle Eye X3R (not filing or grinding needed, fits perfectly )
Samsung LH351D
3535 gasket in buttefly shape (wings were cut )
“blue aqua” GITD tape
the driver is a 17mm DrJones H17Fx Driver w/ lucidrv2 - 7135 + FET
reverse clicky switch with a slightly larger PCB (not from Convoy)
transparent 18mm rubber button with the inner “tongue” shaved and placed in reverse position
outside white/transparent o-rings from the Jaxman E3
CONS from this mod?
well, it is taller than the FWAA and even the DQG Slim Ti AA, and there are some “gaps” that I tried to cover with the white o-rings
- the switch is not stuck in place, it is pressed by the tube, which is in reverse position for that purpose
- it does get HOT AS FOOK in higher levels, since there is no mass to absorb that heat
- I cannot fit a forward switch, for momentary modes, because it is too tall for that tail space
PROS of this mod?
- It is just cool AF to have it and it will be even smaller than the real and upcoming FW1AA
As for the tube, yup, I needed to use it that way to secure the switch PCB, considering that the other end as a wider opening that doesn’t allow contact with the PCB. So I needed to do that.
The other option would be…using the tube of another flashlight, which is also possible :innocent:
I’ve had great luck with removing the donut holes in quad E17A LEDs by sanding down 1 side of the lenses to make them frosted. You can experiment with how much flood vs throw by using different sandpaper grit. But too high of grit (ie. less of a frosted lens) may still result in a slight donut hole. But at least you can control the final beam vs buying something to cover or replace the lens.
Thanks for the screw trick. With that I was finally able to remove the driver from the light.
Unfortunately, it took an enormous amount of force. The board bent slightly and some traces and parts ripped off.
I tried connecting the extracted driver to a battery and switch outside the light. It’s irretrievably dead.
Now I have to figure out what to do with the broken light. The anodizing, lens and switch are all in perfect condition. It would be a shame to just toss this. Some options:
I wonder if Zebralight would be willing to fix it. Or if they have an old SC52 driver they can send me. I guess I’ll try sending them an email. They’re pretty good about responding.
or perhaps I can use it as a host. It’s not great since the space inside the head is so small owing to the one-piece driver/star, but I could probably transplant the guts from an FWAA into it.
EDIT: Quick response from Zebralight. They can’t repair it as they have no SC52 boards in inventory. I guess this light is now a host for me to try to put something else inside.
I guess in attempting to mod this I probably should have started with one of my defective non-functional Zebralights rather than one that was working perfectly.
Taking a closer look at the driver I now see what happened.
The bypass hole for the positive driver wire was completely filled with solder. I wasn’t able to remove it as my solder sucker wasn’t strong enough, and I couldn’t get solder braid in.
To remove the driver, I inserted my soldering iron into the bypass hole while lifting up on the screws with a pliers.
Unfortunately, even though the solder seemed molten, the positive wire actually hadn’t released. And it’s possible the tip of the wire accidentally bent downward and resoldered itself to the positive pad on the top of the driver while I was trying to remove it. The head is quite small and between my iron and the pliers I couldn’t see anything when I tried to remove it.
When I exerted force to remove the driver, it actually ripped the positive contact bondpad from the board, along with the metal can lining the bypass hole. Also ripped off the board was a large trace on the underside that went under the inductor coil from the positive wire to a capacitor. This trace coming off actually tore chunks out of the body of the coil and left the coil dangling from the board.
I also noticed that one of the switch contact pads on the board is dangling. Looks like it ripped mostly off, but is still connected.
As-is, the board doesn’t work at all.
On the upside, I gained some valuable insight into how Zebralights are constructed and what not to do to them.
To think… I might have avoided this problem had I purchased one of those super-powerful cheap solder suckers someone on BLF was talking about 2 weeks ago.
I’m not sure it’s possible to remove all the solder with a wire in a plated through hole even with a powerful solder sucker.
One other trick that I use is to lower the temp of the SAC/SnCu solder with BiSn which melts at 140C, and when things still don’t want to come off I add lead to it, which depending on the proportion of Sn Bi and Pb can melts as low as 95C (Rose’s metal).
Thanks for the suggestion NeutralFan. I’ve done the sandpaper trick while waiting the diffuser stickers to arrive. At first, I tried the 800grit, then tried to the lower and lower grit. At final, 240 grit for one side and 400 grit for the other side, it improves a lot but the donut hole still appeared. Lol
I have a plan to do something similar by replacing stock driver with Tool AA driver or Reylight Pineapple driver.
The goal is to have a triple AA flaslight which support NiMH.
The main challenge would be replacing e-switch with standard clicky one without changing its form factor.
