What is more important to you, AA compatibility, LiIon compatibility, or dual chemistry AA and 14500, with or without PWM?
Thanks for all the comments.
Lucky to be Old :slight_smile:
fwiw, I asked Malkoff what speed PWM his 3 mode MDC uses, the reply:
ā€œThe PWM frequency is 310 Hertz. Most people can’t see it.ā€
I leave it to each individual to decide how they feel about PWM, the poll clearly shows a preference not to have PWM IF there was a choice, but I also see that people are happy to buy lights with PWM that they dont notice. Im guessing most of the people that do not notice, do not try waving the light, and do not take photos of the beam or LED up close.
As a wise man once said, if you dont notice PWM, don’t learn how to detect it or you may regret it. Similar to the High CRI experience, if you are happy with your Cool White Low CRI lights, don’t learn how to detect CRI, and steer clear of Neutral CCT, or you may regret that too. :smiling_imp:
When ReyLight came out with the High CRI, Neutral CCT, and NoPWM Tool, I thought I had entered Nirvana. Imagine my surprise when both the Maratac AA and the Pineapple, came out with PWM drivers…
Its all good… choices are fun… Merry New Year!
What's the excuse for any light having low frequency PWM? Is there some cost savings available using cheaper mcu's that only have low frequency capability? Low speed PWM is pretty unacceptable in fast motion situations. Maybe there's someone it won't bother, but I don't see any reason to do it. A light with low frequency PWM is just designed wrong, or cheap at best.
yeah, what is seen can’t be unseen
but actually, the CRI is not a big deal for me
i am having Astrolux A01 and olight I3s Cu CW, and i like the i3s Cu more(yeah, the price is much more higher)
and the last option is the best, but this is BUDGETlightforum, if i have to pay 10$ more for a 15$ flashlight just to get rid of PWM, i will deny it
i am happy to go with option 3, as long as it has HIGH Frequency PWM, for me, the ability to use many types of battery is more important
7135s have a certain capacitance associated with the input strobe pin. Ɨ8, and that’s a fairly hefty capacitance to overcome with the somewhat anƦmic output pin of a Tiny13. The signal is slowed and rises only gradually, so at low levels (especially moonlight/firefly modes) it ā€œeatsā€ a few counts of the PWM output, sometimes enough that the 7135s don’t even turn on. So a PWM of 8 counts might only ā€œregisterā€ as a 6 (where 256 = 100%), and a PWM of 3 might register as a 1… if it turns on at all. (The difference of 130 vs 128 won’t be noticeable.)
At a lower PWM freq, each pulse is wider, so a PWM of 1 (longer pulse) would be long enough to get the 7135s to turn on; at a higher freq, 1 or 2 (shorter pulses) might not turn them on, but a 3 would (first 1-2 pulses ā€œeatenā€ from the slow risetime).
Wait… what??
Not sure if you mean millihertz or megahertz, but either one is… uhh, wow.
310MHz is like VHF teevee channel frequency.
310mHz is 0.3Hz or a sloooooow turn-signal on a car.
9000mHz is 9Hz, and pretty much everyone can see that kind of flicker.
While I’m making an assumption, I’m pretty sure he meant 9KHz or 9000 Hz. Metric is not clear for everyone.
In any case, Jon, you are really taking this anti-PWM crusade to heart it seems!
I come from the old days, in 2006, 100Hz was common, the Jetbeam CL-E even came out with 80Hz in the first gen model (later improved to 300Hz). Conversely, the old Cree XRE with constant current designs tended to be very green at lower levels.
These days, with modern LEDS and much higher frequency designs (10KHz and above), I find PWM to be fine. My favourite drivers (eg. Dr. Jones H17F) are super powerful, flexible, and programmable. That would not be feasible with a constant current design. It would likely be too complicate, cost too much or be too big. Constant current is preferable to me, but if the PWM frequency is high enough, I don’t mind.
AA compatibility is a must for me. I much prefer the ability to use eneloops in my AA lights. 14500 compatibility is a nice to have for me, but not a requirement. Perhaps useful to make the light weigh less or provide higher max output. That said, a single voltage design is likely more efficient and easier to design (eg. Zebralight SC5).
I see you have mentioned the ReyLight Pineapple. I think it’s PWM was measured at around 2KHz. While I do detect it, I find it reasonable in use. especially since it is not found in the moonlight level. In any case, it’s disappointing but I don’t find it too noticeable. I’m pretty sensitive to PWM, but I’m sure others may find it annoying. I’m glad Rey is raising the frequency to 9Khz in the Ti design though.
On an unrelated note, has anyone tried the new 4Sevens Preon? I have heard it has very bad PWM…
:slight_smile:
Yeah … 9Khz
310Mhz is my garage door frequency
Dual, with or without PWM.
Thanks Lighbringer. I see.. ok.. This would be a problem on the opposite end also, not that anyone cares much there, but a 254 would not regesiter as 245/255 but more like 254.9/255.
So that creates a little non-linearity in the PWM response, maybe complicates unifying software across different configurations (different numbers of 7135's), but in the end you can still do a PWM of 3 though to get the equivilant of the 1, and if it's really only that bad, then that's not so bad at all. There might be some actual energy wasted in driving all that capacitance though, which might bug the survivalists who want 50 days of moonlight mode. Between the two issues, I'd rather have high frequency.
It might get a little more complicated than that, that there’d be a similar lag when turning off, but the main issue is in fact getting the bugger to turn on in the first place when the PWM period for 1 count is about as long as you want to strobe the 7135s.
It’s like turning on a bank of tube fluorescent lights that flicker a bit before catching. That lag is what causes the issue when you just want to turn the lights on for, say, 1sec, when it takes about 1sec for them to catch.
And the bigger problem is that there’s variation elsewhere (7135s, output drive for the Tiny13s, etc.), that some combos will work fine and give you nice low firefly mode, whereas other times it won’t turn on at all, or start fine in firefly but not at all when stepping down from turbo to firefly, etc.
I followed the thread for a while, on setting PWM values on ā€œbiscottiā€, and it got really complicated.
For a Li-cell, the best firefly mode is probably just a dedicated line through a resistor, not PWMing it at all. Besides, as I can attest from my Quark, lowest modes tend to be the greenest (yecch). That’s why PWMing is actually preferred over linear. Linear brings its own issues such as nasty color-shifts in any LED (even monochromatic, not just white). Even 2A vs 2mA is a 1000:1 range.
If I understand correctly, the only reason the Pineapple needed to use PWM was in order to be dual chemistry. If it was only AA and Eneloop powered, PWM would not be needed. Im not sure I understand whether LiIon chemistry would require PWM, like the 7135 uses.
here are photos of the new preon and the malkoff, I do not know the speed of the Preon PWM (it has somewhat green tint, even with PWM… probably due to the LED itself, not the circuit, )
[QUOTE=gurdygurds;5011460]Well I now have two Nichia 219b lights and I’m really enjoying them. Received a Copper worm from Gunga yesterday(thanks again sir) and quite like it. Here is a shot of it next to my Preon P1 gen 2.
And here is a side by side comparing my two Malkoff MDC AA lights. 4000k vs 6200K. I absolutely LOVE these flashlight!
[/QUOTE]
there is a way to determine PWM speed with water drops and a camera with adjustable shutter speed:
[QUOTE=Lexel;4991544]All Convoy lights with 7135 drivers use 4500Hz PWM
[/QUOTE]
regarding tint shift
two XPG2 on high, for tint comparison (NoPWM part of the circuits)
the CC light was greener to begin with, not by a lot, LED variation, not PWM caused since these lights are not in a PWM mode
same two lights on Medium…
I dont see a serious green problem with the CC light in this image
the tint shift is more obvious in this sweep
I dont see a large green shift from CC in my lights with N219b or XP-G2, or XPG… , I suspect the XPE had more of a problem with green tint.
Yep. Tint shift is highly dependent on the LED. Modern day LEDS are likely better.
If the pineapple can be done with CC and 1.5V only? I’m all for it. I would like the max to be increased though. The current 100 lumens or so is pretty weak. It’s okay with dual voltage but not by itself.
I prefer ultra high freq. PWM if I need consistent CRI and tint across the current range. For efficiency current regulated is the best
- Clemence
For me it is important how good the light perform and if its only AA it doesnt get destroyed putting in a lithium battery
PWM should be a few kHz at least
Efficiency in ultra low modes is not so important, who wants to use an AA light for more than 24hours?
If I got a long power outtake, which was last time back in DDR in soviet times, I have plenty of 18650 CC lights which I can use for ceiling bounce light over long periode of time.
I don't see the moonlight as that big of a deal. TA offers multiple hex's with different moonlight settings. IF you're selling a single light you only need to find one that works on that light reliably, and from the sounds of it 5khz would fix it almost entirely and still isn't slow pwm. I think 20khz is still fine though. I guess it just means you need the +1 channel, don't try to do moon with 12 7135's. But that doesn't actually add any cost. It's just about doing it right.
Exactly. Ultrafire 100 Hz PWM is annoying, but I doubt we need a poll to figure that out.
It’s interesting that people interpret ā€œno PWMā€ to include ā€œno visible PWMā€ though. What does ā€œPWMā€ mean to people? More on that below.
I don’t see any ā€œNoPWMā€ lights there. What I see there are four PWM-based lights. This confirms to me that the disagreement is about the definition of PWM, not people’s preferences about the physical properties of light.
Left to right, the PWM speeds on those lights are (approximately):
  • Zebra: 5000 Hz
  • Quark: 2200 Hz
  • Eagle: 4500 Hz
  • Malkoff: 1350 Hz
All four of those are too slow. I have the same Zebralight and EagleTac lights reppans used in that pic, and I can see the PWM on both during normal use. All four are examples of what I call ā€œbad PWMā€.
The v2 Pineapple driver is spec’d at 9000 Hz, which is ~2 to ~6 times faster than the premium-brand lights shown above. Not bad, but not what I’d call good either. Most BLF drivers run at around 14,000 to 18,000 Hz. The new Convoy C8 runs at 32,000 Hz. I find ~20,000 Hz to be ideal, preferably with a FET+1 or FET+N+1 driver for better efficiency.
I like true CC circuits for their efficiency (when done well), but a 2-channel or 3-channel PWM driver is close enough for my purposes. Here’s a qualitative comparison of 1-channel, 2-channel, and 3-channel PWM drivers and their efficiency as compared to an ideal CC driver:
Wow! Great and informative post!
x2… I tried to elude to this in my earlier post, but didn’t really have the detailed information to clarify what I was talking about.
FWIW I am totally OK with PWM, so long as I can not readily see it. My understanding is PWM is the most efficient way to lower LED output too, although I am not sure why. My Thrunite TH20 I just realized uses PWM for its lowest-low / candle setting. I didn’t even realize it until I had it on and was washing my hands in the middle of the night, under the water it became more noticeable. I am OK with that, since its high enough frequency to not be readily visible all the time.
x3 (thanks!)
I would now have to vote for the following after learning the above and when considering the UT01 in transit to me now):
ā€œPWMā€ speed (as now better understood, thanks to toykeeper)…
…quality LVP protection (as evidenced by the NiMH ā€˜only’ shutoff apparently exhibited by the UT01)
…and ā€˜tint’ would be my (off-topic) answers to the OP’s poll involving a 14500 capable light (you can buy a Nichia 219 tinted BLF ā€˜backup’ light for $7 and a Jaxman for less than $20 so ā€˜tint’ has become less important to me…yet it’s always nice to have).
I’d really like to standardize more on AA cells and the protected versions for at least 500 lumens in a single cell EDC light.
