Yeh. All it needed was charging and it would’ve been ideal. Needing to break out a 4-bay charger each time, then having to screw with the dinky O-ring that did what it could to try to escape every time it needed to be opened’n’closed, was the biggest pain in the ass.
That inconvenience is why I switched to a DC7 as my go-to big donk. Cooler and throwier vs warmer and floodier as I like, and a dumbed-down UI vs Narsim, yet being able to charge all 4 cells in situ is what wins out.
And I get the feeling any “Q8 Pro” will still have the cooler/throwier setup vs the original, and probably an overloaded UI.
I prefer to monitor my batteries, so 4-bay chargers all the way, but no issues with lights with USB charging even if I don’t use it.
The Convoy 4x18 has a nice simple UI, good heat handling, and USB charging, but sadly lacks a tripod thread.
Agreed about the charging - if Sofirn is indeed launching a Q8 Pro with 4x XHP50.2 3V and built-in USB-C charging, my Supfire M6 with three XHP50.2 3V and no charging is toast!
Maybe that’s why I woke up in the middle of the night recently and drew this on my phone before going back to sleep?
It’s a plan to add usb charging into the tailcap of my M6. Opening it and charging all four cells sucks, especially since it has a retaining ring rather than screws holding the driver in, and it tends to loosen slightly when opened. If I forget to re-tighten, it does all sorts of funny things with an unstable ground connection.
The idea is: drill a hole in the center of the tail PCB. Run a wire up to the positive end and put an upside-down spring on it (narrow end facing the tail) to contact the battery + contact on the driver. To hold the wire I was thinking some sort of plastic tube, similar to a pen’s ink tube. Negative is obviously easily available on the tail board. Then I find a way to mount (glue? epoxy?) the darn thing and USB-C charging’s my uncle.
How about something with some kind of remote control. Wireless preferably. Bluetooth maybe? The internet of things (IOT) seems to be a popular subject. That could spill into a whole new realm of possible uses.
For instance; Have you ever been working on something and set your light down turned off and then spent 10 minutes trying to find it? If you didnt do the same thing with your keys then a keychain remote to send a signal for a blink or two would be nice.
If you’re chasing millimeters, you should note than the PL47 is larger but trigger619 asked for a “right angle headlamp like the size of the fw3a” which for me implicitly means 18650, not 21700.
But anyway, 4500 lumens is way too powerful for a headlamp of the size of the PL47/FW3A in my book. I’m so tired of the “pocket rocket” recent trend, with more an more people taking the turbo output as some sort of reference. For me both headlamps are not 4500 lumens headlamps. Expecting more lumens from a headlamp of that size…really ?
But forget it, it’s just my opinion and I’m not here to decide what people should want.
As a few others have mentioned a well designed, slim & rugged AA/14500 light focused on EDC would be wonderful. A light where the clip & ergos get as much attention as the emitter.
I would also like to see a modern take on the emergency beacon/signal light. Something that fall into roughly the same form factor as the lowly chemlight. Multiple colored emitters, possibly including IR. Indestructible (ish).
I’d like to see a 5A single AA (Eneloop only, no 14500 Li-ion support) flashlight, aluminum host, black ano., diamond knurling, tailstanding forward tail clicky with rubber boot, 1-inch diameter female head with plain bezel (no crenellations or scallops), 3 modes, 5Lm, 50Lm, 500Lm, polarity protected current regulated constant current driver with low voltage protection (constant brightness, no PWM, no step down, cuts out at 1.05V), copper bonded high CRI 3500K emitter below the BBL with no cast of any kind (sandy), borosilicate glass lens, aluminum silvered reflector, potted electronics, screwed on deep carry clip, waterproof, and a bag of Cheetoh’s.
What about designing and fabricating the longest sustainable running flashlight on the market. We have the thrower category and the flooder and the highest lumen torches. The longest running torch I own is the original GT, it seems to run all night long when the family’s out playing at night. It gets warm but holds turbo like nothing else I own. I am no engineer but don’t think it would be that difficult to achieve. What about adding twice the mass to the FT03 for example and limiting it to 1.5K lumens. Poor example I’m sure but something along those lines. I love my FW21 Pro, NSX3A and other hotrod torches but getting a bit tired of the super duper lights not being able to even run on high for long periods of time. What does everyone else think? Am I just dreaming or is the technology still not there.
