Ordered a new Multimeter at DX (Vichy VC99) and won a $20 Giftcard on the BlackFriday Carnival. Now what to buy, Hmmm…
AFAIK, that giftcard can be used on purchases over 100$
Last week received the following lights:
1. Lumintop SD10 (2nd purchase from hkequipment)
2. Rofis JR30 CREE G2 (from aliexpress)
3. Rofis JR10 CREE G2 (from flashlightshop.de)
4. Rofis JR40 CREE G2 (from flashlightshop.de)
5. 3 pcs of Rofis ER12 SS CREE G2 (from flashlightshop.de)
6. 2 pcs of Rofis ER12 CREE G2 (from flashlightshop.de)
7. 7 pcs of free Fenix E01 black (from flashlightshop.de)
Just received two packages from DX:
First contained 4x of the Sharp Air folding knives from DX as stocking stuffer items for in-laws at Christmas:
Ordered 11/12/13, Shipped 11/16/13, Received 12/2/13 - 20-day turnaround including Thanksgiving Holiday.
Second contained 1 pair each of TrustFire 14500 and 16340 cells. Ordered from DX due to the crack-down at FT in fear that other sellers might be following.
Ordered 11/15/13, Shipped 11/17/13, Received 12/2/13 - 17-day turnaround including Thanksgiving Holiday!
I have a second order I made the same day for a pair of 18350 cells I'm expecting very soon as well.
Be super careful with those Only good ones are Sanyo 840mah 14500
My first ever “host” arrived, an empty L2M waiting for its $100 dropin
-Jamie M.
Yesterday I got a black SK58 from Price Angels, TOTO88 | Bocoran Slot Gacor Hari Ini . The parts are not interchangeable with those of the other two I have. I think the other two are close to original Sipik SK58 design, though none of them displays a brand name. The new one has the led deeper in the pill than the others, and its circular spring to control the head movement is on the body rather than on the pill like the others and like SK68s and most other zoomies. The ad. shows a picture of one that has Sipik written on it, but its text only says SK58. The new one is really the nicest, because the knurling is deeper. On the head, the longitudinal spacing is shorter and there are micro-grooves on top of the main knurling, in the circumferential direction that helps the grip to zoom the focus. One of my best AA lights.
Do the tail caps interchange?
Some neon light wire, because I was curious. From fleabay.
We used to use stuff like this years ago to “decorate” server rooms:
and some Polymer Clay. Also Fleabay. This stuff is great for kids. Once baked it sets into a plastic material like Sugru:
An order from IOS
10x 16mm blue boots (not cyan GITD)
4x 14mm blue boots (came cyan(ish) but not GITD... wanted BLUE)
2x 14mm(?) orange boots (cant remember, almost think they are actually like 15.3mm or something?)
5x 17mm blank PCB (DD drivers)
noctigons:
2x xp 16mm
2x xp 20mm
2x triple xp
2x xm 16mm
2x xm 20mm
so pretty much almost 1 order of each
should be able to have some fun this weekend now
cool haul. be sure to post up some builds.
I got this
<a href=Photo Storage | Photobucket target=_blank><img src=http://i185.photobucket.com/albums/x48/gords1001/20131204_181320_zps33c57227.jpg border=0 alt=>
really finishes off the roller nicely I feel.
no torch mail, and this was bought as a leak free set up for visiting Alice. ….sadly not necessary now, but it will see much use anyway.
Is than an rba or a tank? I need to get back into experimenting with the new vape gear
It is kind of like a BCC like the pro tank but way better. You build a wick out of silica or cotton or the like and the ends come out the bottom of the main chamber to the tank to wick the juice to the coil. It’s the same principle of a pro tank.
Here is a pic of the coil/wick setup. Then the main chamber goes over it and then the tank goes around the whole thing and the juice sits between the tank and the main chamber.
I have been running a Russian 91% lately and like it a lot. I wouldn’t mind getting a Fogger clone sometime. I can’t afford the real thing. I just ordered some Kayfun 3.1 clones for $22 each and another Nemesis clone.
A lot has changed in the vape world since I started 3 or so years ago...
You guys want to read the history on these rebuildables search ecf for a post called all my mods by raidy
I heard that starting from 2014 selling e cigs will be banned in EU, allegedly they prove to be cancerous for a long term use!
sirius, thats whats being bandied about……by pharmaceutical companies that use the self same ingredients in their nicotine replacement therapy products……
its like this……ecigs work, they work well, within a month I was onto zero nicotine juice. that’s right, no nicotine, just vegetable gluten, food grade polypropylene glycol and flavorings the same as used in cakes….you are at as much risk as me if you consume……basically anything factory produced, use an inhaler so on and so forth.
pulsar. what I got is a fogger v2. its essentially the same design as a kayfun/taifun/protank, atomiser in a chamber in the bottom, tank and juice flow is controlled by wick density. it is nothing like the foggatti that the fogger font is ripped off, it borrows ideas from all over the place.
its not bad, it has some things that need addressing (airflow, I’m looking at you!) but its not leaked, not given a dry hit till I ran it at 15watts chain vaping. it cost me less than 20 pounds delivered.
After trying a vertical coil cartomiser style setup, which flooded miserably, I wrapped a 1.6ohm .25 kanthal 2mm micro coil and fed in some cotton wool. its working a treat and the tanks lasted all day using it exclusively, exactly what I wanted from it, I could also use an 18350 in the roller for going out of an evening, no messing with dripping.
the foggatti is a high end genesis (top coil and wick) atomiser, very good, but still likely to leak in a pocket and so,not ideal for this task.
personally, I love these bottom coilers but I’ve still not found a budget one that doesn’t need a little work to be spot on, this is dammed close though.
ihartman, I really need to get a Russian 91% at some point, they seem to be the standard to aim for.
Fresh order from GoingGear, 2 pill fobs(one pictured), 2 16340 Eagletac batteries, a mini ferro rod, and a patch for a friend.
I'm pretty excited for our electronic load that just came in. We've checked the voltage accuracy with our NIST calibrated multimeter and everything's on the dot. We'll finally be able to release legitimately accurate battery tests and charts instead of the rubbish CBA4 we've been running. Time for science!
Purrdy, what camera did you use to take the pic?
-Jamie M.
Canon 5D3, a bit overkill but it was the closest thing to me other than my cell phone camera.
Nice, I appreciate the quality
-Jamie M.
