This is an old diagram, but change a few of the labels and the same idea still applies…
On one of the early FET+1 style lights, the ramp was calculated to exactly match up with the bottom channel’s ~130 lm regulated output plus the top channel’s ~1500 lm direct-drive output. The result ends up looking visually linear.
Take that same driver though, and give it 4X as many LEDs, and the relative brightnesses are suddenly 130 lm and 4000 lm. The ratio changed. So with no changes to the driver or firmware, suddenly the ramp is the wrong shape. Instead of being linear, it has an “elbow”.
Or replace the LED with something much weaker, and the ratio changes in the opposite direction… like 100 lm and 300 lm. So it gets an inverted elbow.
For Hank’s linear+DDFET lights, it’s kind of a similar situation. But in this case, the ramp is calculated to be linear with 5A on the bottom and maybe 15A on top. When you change it to be 12A bottom and 15A top, the ramp shape then looks like the picture on the right. It ramps up faster until it hits the channel boundary, and then suddenly the rest of the ramp increases slowly instead.
This can be fixed with firmware modifications, of course. If the 5A limit hits at ramp step 120/150, perhaps the 12A limit should hit at 130/150 or even 140/150. The exact spot is generally determined by measuring output of each channel and applying a curve to see where things land, then usually trying to adjust it until things line up with a round number.
But that type of fine-tuning ideally would be done for each emitter type on each driver type on each host type… and that’s not feasible. So the firmware is built as more of a “one size fits all” or at least “one size fits many”.
Anyway, that’s only one aspect of all this. There are other factors too… like the driver details tend to affect the moon level in ways firmware can’t fix. And it changes the thermal characteristics and regulation pattern, since it moves a few Watts of heat to a different part of the light.
The impact is likely not huge, but also likely not a thing you’ll be able to find hard data about… because there are so many different hardware combinations, and so few measurements and reviews. So the exact consequences of the hardware change are probably unknown, and the best anyone can do is make educated guesses.
