Hi, First I tried it on my regular 6x Tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green) [image] I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work first get the voltage and resistor value for each LED at the same brightness [image] [image] Then I made some calculatio…
