Wurkkos TS22 high parasitic drain, and overcharging
And I did retest it, and it's strange... (remember the auto lock is enabled only when the button is OFF. )
button ON: it will just stay 3640µA even after 3 min (but when you lock it actively by 4C it will go down to 2000-1960µA with button backlit OFF, and stay there, no jumping every couple second)
So even if you lock it, and button backlit is OFF, the driver seems to be awake, and drawing 2000-1960µA (that will drain the light full 21700 5000mAh in around 3 months)! even after 3 min it's still drawing 2000-1960µA
button blinki: it will just stay 2000-1960µA jumping to 2800µA, or 3600µA every second blink even after 3 min (but when you lock it actively by 4C it will go down to 2000-1960µA with button backlit OFF, and stay there, no jumping every couple second)
So even if you lock it, and button backlit is OFF, the driver seems to be awake, and drawing 2000-1960µA (that will drain the light full 21700 5000mAh in around 3 months)! ) even after 3 min it's still drawing 2000-1960µA
button OFF: it will just stay 130-110µA when off, jumping to 1960µA briefly every 5 seconds or so, (probably to check the battery), but after 3 min the jumping cease to happen, and it's just t stay 130-110µA all the time.
when you lock it actively by 4C it will stay 130-110µA with button backlit OFF, and no jumping every couple second.
So is it the auto lock function that is jumping the parasitic drain every couple of seconds? why would it do that, I thought it just woke up the driver, to check the battery voltage. And in button blinking mode, auto lock is disable, but the parasitic drain jumps are still present every second blink (well I assume it just because, every second blink, have different parasitic drain value 2800µA or 3600µA, it could be that one blink is dimmer, and I just don't see it).
And the button ON / button blinking, when actively locked by 4C, seems to be bugged.
