Yeh, you don’t want it to ramp like a RJ02… ![]()
When (if?) you get yours, lemme know if it’s true buck/boost. The 2577, well, I’ve only seen in plain boost config with a single inductor, and you’d need an actual transformer for buck/boost. Or, you end up with negative output from positive input (and both these grounds are in common and imply positive/positive).
And if you look at that .pdf, all the sample circuits have 12V-16V input for 18V output. And the only SEPIC circuits in there use transformers, not plain inductors.
The converter's topology looks like this one found in the manual, so I think it's buck boost no doubt.
By the way, a transformer basically are two coupled coils. An XL6009 can handle its coil pair for it to operate like variable transformer, or so I think.
Yeah, we'll see.
But there’s zero coupling between the two coils.
Unno, maybe they’ve got some trick circuit that lets it be a buck/boost, but…
Like I said, when (if) I get mine, I’ll put it to the test. Would actually be nice if it were a true b-b. Lots lots lots more flexible for the stuff I could do with it.
SEPIC doesn’t require coupling between the coils, although you can often reduce the space taken up by the coils if they are coupled (which increases their effective inductance) and thereby build a smaller conversion module.
See here:
and scroll down to “Using a Transformer”.
As usual with inexpensive Chinese modules, the simplest way to find out is to buy one and see what it does ![]()
Wellp, mine are currently (haha, get it?) in “pre-shipment”, so maybe by June…
My modules were shipped already. It is a good thing that Correos (main Spanish postal operator by far) reached an agreement with Sinotrans Limited a few years ago, I can choose Ali Saver or Ali Standard and the majority of times this means Sinotrans - Correos which comes home quite fast.
I'll be able to take a quick peek at the modules next week. ;-)
Well, a little faster than expected:
So it matches the title well, it is based on an LM2577-ADJ integrated circuit. The board layout is a little bit different, namely at the switcher's leads for obvious reasons. Whether it is buck boost or not it a mistery is to me until I try it with my PSU, but it should.
I just got mine yesterday, too. Didn’t mess with them yet, though.
Underside pictures. Notice the current sense track, right at the voltage trimpot's feet.
I've quick tested one. Fed with 7.24V from my PSU I've been able to adjust the output all the way up to 26.9V, and all the way down to 1.237V according to my Bside/Zotek ZT102 multimeter. Voltage adjustment is sort of logarithmic, took a lot of turns down from 3V. Hence, whoever devised this module knows something. ;-)
The unmarked chip next to the 78L05 regulator must be an LF351 or LM351 amplifier for the current sense thing. Compared to other modules this thing is using a quite low resistance current sense track, like 10mΩ or so.
Yeh, I mentioned that up nyah (#9). Nice.
Kewl, so it is a b/b converter…
They sound useful enough to get a pile more. :laughing:
This LM2577S single switcher seems uncommon to me, I've had it on my wishlist for ages but finally decided it was time to give it a try.
Another buck boost topology:
That one has end current percentage turn lamp setting and two switcher ICs: LM2577S + LM2596S. Besides this, the above board is marked as XW036FR4, whereas the one discussed here is marked as XW036NFR4 (check it in my #28 reply).
Wow… buy 5, get 1 at 5% off! That’s a whopping 1% off the total!
Now Maw kin git that operashun…
So whut’re the 3 trimpots for? Voltage, current, and…?
3rd trimpot is usually for end of charge (low current) detection adjustment
That last kind of converter theorically has a lower efficiency as it's made with a boost converter followed by a buck converter so you have to account for the two stages losses
Hmm, that can come in handy.
The setting on the OP boards is a fixed ratio instead of adjustable, then.
Still trying to figure out where the turn-signal comes in…
The turn signal is meant to indicate at which point the current output is lower than the given ratio, for battery charging duties namely. It is set fixed as 1/10th in the OP module.
I have an interesting question, because as I see this module it looks like it is parallelizing friendly. First of all the diode at the output makes it reverse current inmune. Next question is, is it reasonably possible to use the same control trimpots/potentiometers for two or more modules? The idea is to use common voltage and current trimpots/potentiometers, this way the modules should share load with great balance…
Cheers ^:)
Sorry i don't understand what you mean with "turn-signal"
Here is a simplified schematic for a CC/CV buck driver :
The two "FB" points are connected together
R3 sets the max voltage
R2 sets the max current, D2 might be a led indicating that the converter is worlking in constant current mode
The third trimmer sets the reference voltage on an other comparator for lighting a led indicating the end of charge
Nah, it’s a joke. Like the funny kind, only different.
In car manuals, they’re called “turn lamps”, not “turn signals”, just like “CHMSL” vs “3rd brake light”. So when the spex for this donk kept referring to a “turn lamp”, well…
That doesn’t usually work, as the converters will have very slightly different feedback voltages.
For example, if you put two in parallel, one might go to standby at 0.60V of feedback and the other might go to standby at 0.61V. What happens then is that one will stop converting before the other, so that the other ends up bearing all the load and either frying or shutting down. At that point, the first one has to bear all the load and either fries or shuts down as well.
You might get away with it if you use trimpots on each module to adjust for the different feedback voltages, in addition to your main control potentiometer, and add load-balancing power resistors in series with your module outputs, but that gets very fiddly, especially if you’re doing it for more than one control.
You can also run into problems with things like thermal effects under load making the feedback voltages drift at different rates, so you end up back where you started with one module trying to bear the entire load again.
Easier if you just buy a more powerful converter module in the first place.
