What a fun mod!
After reading the OP, I realized this is a task I could probably pull off, but didn’t want to make an attempt on any of the XM-L lights I currently have because I like them too much to ruin an emitter and have to wait for a replacement.
Then I remembered I still have a generic 5-mode XM-L T6 drop-in that came with my first P60 - an UF wf-502b from amazon. This drop-in noticeably under-performs compared to the MF UF 3-mode T6, and I suspect it’s because it is under-driven. Either way, seemed like a good candidate for my first intrusive mod in the form of de-doming that LED.
I do not have a razor blade, but I do have a very small Kershaw pocket knife with a VERY thin blade. I sharpened it up a bit, and quite easily sliced off about 50% of the silicone dome. It was not a perfectly straight cut, and seemed to leave some artifacts and ridges, etc. But I tried it out anyway, re-assembled the drop-in and put it in my 501a with a 18350.
The hot spot, while not particularly pretty or even, was noticeably smaller and seemed hotter too. Compared to a MF UF 3-mode T6 in my L2M with the same TFF 18350, it now was ALMOST as bright as the higher-driven drop-in. NICE. However, like I said, the spot was kind of ugly, uneven, and even had some small rings around it.
Of course, given that this was yesterday, now after revisiting this thread and seeing several more posts and ideas thrown about, I decided to make further attempts to improve the beam on this emitter. I pulled out my dremel, and used the polishing point as pictured in one of the posts above, and carefully touched the remaining “dome” to the spinning head until it was flattened and smoothed out evenly. It left the surface frosted, so I switched the polishing head out for a soft felt disc, and went back at it… polished the silicone surface out til it appeared to be perfectly clear.
I reassembled the light and eyeballed the beam on white wall again, and yes - it has improved drastically. It is, as reported by others, a slightly warmer white than the unaltered UF 3-mode T6, but damn if it isn’t somehow, at least to the naked eye, matching the output, even under-driven.
Last night before today’s polishing session, I played around with this light outside, and couldn’t tell for sure how much better the throw was, but now I’m pretty sure it’ll be more obvious. Again - I had only removed about 50% of the silicone originally, and I suspect there’s still a good 30% or so left after polishing. There is definitely less spill, and the spot is definitely hotter and a bit smaller. So I’m happy with the mod thus far - but does anyone think a 30% is still too much? Could I improve this even more? Should I even bother? At this point, I’m really tempted to de-dome one of my 3 MF UF 3-modes. With the results on this generic, I’ll bet the same on the hotter drop-in would be killer.
