well, it apparently is not an emitter board: no led solder pads. It would have been nice if it was one though..
No, it’s for those craptastic Chinese egg-drop style emitters.
That board is designed for LEDs with the little +ve and -ve legs such as the older Seoul P4 or Luxeon LEDs. Even if it was designed for an XML, at 1W, A 20mm star alone would get pretty hot. (not sure how hot though but I’m sure if you put your tongue on it, you wouldn’t like it lol )
Well you can’t reflow an XML to that board. That looks like it is for a seoul emitter.
Also, if you want to run it off alkalines, you need at least two of them in series with a linear regulator.
With the dropout of the AMC7135, you probably won’t even get the 350mA from two alkalines, at least not for very long,
so you’d need 3 in series.
Regarding heat: 350mA through a led equals roughly 1W of heat (in the emitter). If you run that board with 3 alkalines (4.5V), then the 7135 will also generate some heat, about 0.5W. Without any heatsink this might get quite warm after a while, but you shouldn’t need too much of a heatsink.
Very interesting. A fast and easy solution for upgrading a cheap Incan kitchen drawer light. You can add a second chip too, for 700mA.
That's what I thought. I guess there is no option for a similar board for Cree emitters.
Well you can’t reflow an XML to that board. That looks like it is for a seoul emitter. Also, if you want to run it off alkalines, you need at least two of them in series with a linear regulator. With the dropout of the AMC7135, you probably won’t even get the 350mA from two alkalines, at least not for very long, so you’d need 3 in series. Regarding heat: 350mA through a led equals roughly 1W of heat (in the emitter). If you run that board with 3 alkalines (4.5V), then the 7135 will also generate some heat, about 0.5W. Without any heatsink this might get quite warm after a while, but you shouldn’t need too much of a heatsink.
This light uses 4 AA's in series, although I could mod it to 3AA if I needed to lower voltage.
Exactly my idea, but I was planning this for my 8 year old daughter to use in her room or walking to her friends house. She tends to set lights down and leave them on.
-Garry
won’t need much heatsinking.
i opened up an energizer 1W headlamp, removed the xp-c and put in an xm-l. the ‘heatsink’ has the mass of maybe 2 or 3 20mm stars, has no path to the ouside and is surrounded by plastic. the light works great.
won’t need much heatsinking. i opened up an energizer 1W headlamp, removed the xp-c and put in an xm-l. the ‘heatsink’ has the mass of maybe 2 or 3 20mm stars, has no path to the ouside and is surrounded by plastic. the light works great.
Thats about how this will be. I could add something for a heatsink up to about 5mm, perhaps 10mm thick.
-Garry
Interesting, I was just going to ask a similar question. I’m modding a flashlight that was given to me, has an old lumileds star and emitter in it, pretty anemic output. Driven by 3 AAA’s. I was going to swap the star with one I got from sinkpad for an xml2 or xpg2, but was worried about the fairly bad heatsinking. The star fits inside a hollow collar that then screws into the body of the flashlight, so at least it will transfer some heat to the body. I was thinking of adding a small stick on heatsink from a computer memory kit to the pack of the sinkpad.
How about these warm white luxeon rebels on 7135 stars?
http://www.ebay.com/itm/10x-2-3W-LED-3-2-6V-500mA-Warm-White-for-Camping-Light-DIY-/180857225621
Under $1 each, decent efficiency, warm tint, and you could always remove one of the 7135 chips for longer runtime.
Hypothetically that should be extremely easy to make, once I have a WORKING XML library file I could probably make one of those for an XML. However that probably won't be for a while. :(
How about these warm white luxeon rebels on 7135 stars? http://www.ebay.com/itm/10x-2-3W-LED-3-2-6V-500mA-Warm-White-for-Camping-Light-DIY-/180857225621 Under $1 each, decent efficiency, warm tint, and you could always remove one of the 7135 chips for longer runtime.
That's interesting. Seems a bit too warm for my taste and I don't see any other choice in that seller's Ebay store. Also, if they are 7135's, why is it 500mA output? Are they are lower bin of 7135's?
-Garry
Thinking again, I guess I could use the board in the O.P. sort of like a "driver board" and just wire a standard XM-L on a star from that board. That would work, right? It could be perfect if that center pad is where my B+ contact could be made. Anyone know if that's B+ at the center?
-Garry
that’s a pretty good idea - you could epoxy or screw the two together, bottom to bottom.
i bet w/ a 20mm copper sinkpad plus that, you’d be ok w/ 1W, if you don’t mind a little heat sag
I would guess, that you can glue an XML with removed contacts, on the middle plate. Then wire them from the top like the direct on copper style…
-Garry
No, center pad should be electrically neutral, at least in stock form. Look close and you can see the traces. If the center pad is also isolated from the backing, you could easily make it the B+ with a jumper wire.
True! Good idea.
-Garry
garrybunk,
Just noticed your address, small world, I work in Johnstown.
Hey Garry, you could take an XML star and glue a 7135 to it, wire B+ to led+ and Vdd pin, led- to 7135 output, and 7135 gnd to B-. It’ll work anywhere, in just about any host. There just isn’t that much heat generated at .35A.
