>>>>>>those hotspots are very different size.
As I said way back in the beginning of the thread, because of differences between the stock star and replacement star, the XM-L2 star is recessed maybe .5mm-.25mm (1/2-1/4mm) lower than the stock star, hence the slightly different sized spots. The solder connections on a 21-mm star need a super thin spacer to prevent shorting against the reflector.
Yes the L2 could be reflowed onto a properly size GIANT star to make the comparisons exacty the same, but I will leave that to others. The spot sizes are less different the farther away they are, i.e., the outside spots are not that different in size. And spots-size doesn’t matter in tailstanding tests.
Tailstanding shows the L2 maybe an almost undetectable hair brighter than the stock T6.
Yes, the test is slightly imperfect, but please don’t forget that I upgraded TWO lights. The XM-L2 in the aurabuy C8 fits exactly the same as the original stock T6. I am waiting for more exact-same aurabuy C8s to compare with the L2 modded C8. BUT, the point is, in the C8 with the L2, I also can see very VERY plainly that the XM-L2 in the C8 is LESS bright than similar C8s with U2s/U3s and not that much brighter than a stock aurabuy C8.
I mentioned that I have two MORE lights intended for this L2-comparison project, two exact-same A0 clones. I have decided not to change one to an xm-l2 but will use a U3 instead. Why? Because I tried both the modded Small sun and modded C8 last night, and the L2 tint is just horrible for this landscape.
And there is NO DOUBT in my mind that the U3 — for me anyway — is the preferred upgrade with noticebly more light, minus the yellowy orange tint of the L2s that I have. So I won’t be doing a third light. Perhaps others will find better-performing L2s from different vendors. But stick a fork in me, I’m done with this project.
ESPECIALLY since last night I noticed that the bottom fell out of whatever brightness the L2 offered when it hit about 3.95 volts. Both L2s became noticeably dimmer. Could this be the more aggressive power demands of the L2 that others have mentioned? I don’t know. Yes, it could be the drivers I am using I suppose, but this sudden dimness did NOT happen with the stock emitters.
This is yet another reason, i will be passing on the L2 for now.
Perhaps with dedicated drivers in lights designed for this new emitter, the promised increased brightness will shine through, but as a drop-in upgrade in existing T6 lights, I am just not seeing ANY benefit to the L2 over the U3 or even a heavily driven T6 in some cases.
I really really wish that others with L2s would post some comparative beam shots. And I hope if others decide to do the L2 upgrade that they will post the results on BLF so we all can get a better handle on what this new emitter offers or doesn’t offer.
Finally, not meaning to sound like a broken record, as one BLFer said in this thread, technical specs are one thing but real-life testing is quite another. I can see NO 20-27% increase in brightness with the L2 over a T6 and certainly NOT over a U3 or even a U2. I WANT to see that increase. I didn’t set out to trash or dis the L2. I wanted a brighter emitter.
I hope others will pick up the testing gauntlet and prove me wrong. Do some more tests; post them here on BLF showing what a super-bright emitter the L2 is.
The second I can see how to make this emitter work, i will be back in line to buy more and use them in the way that does make them brighter. But, until that time, my L2 testing is done. I’m sticking with U3s and heavily driven T6s.
Thanks to everyone for their comments and their help.
