It would have been smart if Zanflare designed the B3 with the 20mm standard (an MTBR requested spec.) but unfortunately they chose a smaller diameter very shallow OP reflector. It may be possible to grind down a elliptical reflector cover as a replacement for the stock cover. Not sure what kind of beam you'd end up with since the stock reflector is very floody but should at least improve the excessive top spill some.
