But being an Zoomie guy myself and reading through here makes me fell like a fat kid who found a candyshop all you can eat voucher.
However, it stops so abruptly at 07/14/2011 when bushytails has run out of thermal epoxy, and I´m like " Nooooo"
(The fat kid learns that there are no more skittles to be had)
So how did it go? Have you worked more with it or are you still waiting for money/shipping on the thermal epoxy? Or did you finish it and it turned out so nice you are just keeping it to yourself ? ( My precious ohh my precisous ;) )
One more aspheric you might give a chance... the Tank007 TK-736 T6. It is probably the original to the discount clones but certainly a cut above the lesser copies.
The 736 bosts a reflector, a brass pill with a solid emitter base, a more robust switch on a PCB, and nice host of o-rings to seal it up. As a matter of fact, the o-rings hold so well that the light rarely maintains the set zoom position due to pressure/vacuum inside the body tube (easily fixed but the only downside).
The body is well made. It runs true in the lathe which really worked well for a simple mod to use the DX 28mm glass aspheric. The driver is a 17mm so if you don't like the 2.1A drive, you can easily put in your favorite driver.
Great review(-s-), but why does everyone keep saying Sipik SK68 is brighter on 14500s? The difference is unnoticeable with rechargeable AAs. Can't tell a bit of difference.
I think there may be something wrong woth your sipik sk68!
On all of the ones I've had/have or gifted away there is a BIG difference. So either yours have a driver that fully utilize the power potential of the rechargeable AA or there is something the miss with it.
I have 2 in mu current possession and just tried to shine them across the road where I live with a fully charged AA and a 14500 lion in some state of charge and it is still very noticeable on mine.
Interesting. Where did you get yours? I've had 4 sk68s and all are brighter on 14500. It could also be the battery. You are using decent 14500 right, at 4.2V?
I have the Tank737 T6 and its my favourite ‘stock’ zoomie.
Have tried the glass 28mm DX lens, but actually the plastic one is the better aspheric of the two.
I dremeled down the inside of the bezel and it now holds an Ahortons lens.
Dont see how to acces the led and driver without special tools, but it runs well as long as you dont want high CRI.
For all who are following this topic and havent seen this review by JohnnyMac, should read it!
Although I dont have the Z8 yet, it seems like a excellent 14500 FTT and I think that it should be taken into this great comparison thread.
