Having a very clear vision on how the projects I am deeply invested in should be done. As open as possible, and this requires the people in the team to act a certain way to make it work. Gently and keeping the high spirit despite negativity some people will bring, make things that could be seen as negative not so, and in a short period fires are put out.
Right now I see two methods being mixed, and causing problems.
This is costing me energy and will not stop since I see now two fundamentally different approaches are making this harder then needed or then the project and BLF deserves, I apologise for not acting on this sooner and taking this step long ago when it became clear my way of doing it does not work in this setting.
Brr the horror that people see me as being in charge, there are/were lots of projects being done with people actually in charge and one of the reasons for starting the Q8 the way I did was because I have the vision this is not needed and was very lucky the Q-team as a whole acts in such a way to make it possible to have the enormous positive flow I know BLF to have in many aspects :THUMBS-UP:
No disrespect of other ways, they have proven to work fine many times.
Apologies for wasting time and energy trying to get the Q8 flow going here, and not seeing forces are against that.
I can be considered out of the process and will just update the OP and first posts, when team members send me a PM or email with what you want posted and where, I'll do it.
No problem in having different approaches but trying to mix the two proves to be not working fine and that is a shame. It also takes time and energy better spent on other things.
Good luck making this monster a reality :THUMBS-UP:
Teacher, I’m working with/on that design so at this point it is still in.
To everyone, if you want to have the gt made please drop this discussion.
There is nothing more to say, all important questions are answered and everything you need to know is said.
We will give an update when we have one.
Not surprized, but it makes no difference; ‘thijsco19’ was gracious enough to provide a simple, uncomplicated answer.
Thank you, I shall endeavor to move ahead always, hopefully you shall also…. as well as Forever Upward. :+1:
Ahead & Upward…. despite bumps in the road, a great combination.
Err… drop the conversation??
What’s going on here? I’m totally lost. There has been literally 90% less banter on here for the last 2 weeks, than anytime before.
I’m getting the impression something is going on certain members don’t want us to know about. If the conversation is to be “dropped” why even start a GT thread?
This is BS. All the drama is over, we want answers and updates and now we are being told to not discuss anything?? Bollocks. 100%.
Thank god. I just wanted to cut the crap before it started all over again.
This is exactly what I ment with ‘drop it’. There is nothing “going on”.
Obviously I was referring to all the drama. Its perfectly fine to talk about the GT. (might be better if I’ve said drop the drama)
All that need to be said from the team is said. There are no updates at this point afaik, all the questions are answered.
It looks like instead of machining the reflector they use a technical procedure called deep drawing. Once you have the form the production is be very cheap. My guess is that these reflectors are used in those cheap handheld plastic led “searchlights” where they sell high quantities.
So, if your “guess” is correct fritz15; do you think this type of reflector would be suitable for the “GT”?? Or would it just be a cheap compromise that sacrificed preformance?
Any thoughts or guesses at this point?
My guess there is that there is a reason most or basically all flashlights known to me use a reflector which is turned on a lathe. But I really don’t know very much about that so I’m probably the wrong one to ask.
