That thin string will fall under normal wear and tear and, as such, is up to the user to check and maintain. The mfr. is not likely to warranty a wear and tear item, or damages caused by failure due to lack of maintenance.
+1 … Yep. :+1:
I am pretty sure no flashlight manufacturer makes their own lanyards…
That would be a huge waste of effort and money.
They probably just bulk order them from china with the brand name printed on it.
give me a break, this is a flashlights that should come with a lanyard that will not break down so easy i didnt do any over wear really it just snapped, lucky u can easy switch it but still its silly the hole is big enough for a wire alot thicker , and its strange the lanyard to my s1 baton is identical to the m22, to me it should be thicker because the light is bigger and weights more dont u agree? olight dropped the ball here sadly. Thankfully the lights dont break so easily so im happy the light can sustain falls.
Keyring is a good suggestion think i will do that, now lets wear and tear off that keyring then haha
Let me make sure I have this correct………
- Is this the light you are referring to?
- And the lanyard attaches on the tactical ring?
- And this is what your lanyard looked like when it “broke” after 6 months use?
- And you think it is Olight’s fault?
Surely you jest………… :person_facepalming:
It has been said already but Olight , ThruNite , Nitecore , Manker and even the all mighty Surfire (all the companies) , more than likely buy the lanyards in bulk that come with their lights and throw one in with each light packaged.
None of them make the lanyards themselves more than likely and 90 to 95% of the lights you receive , regardless of the brand of light or the size of the light , come with the standard lanyard like you received with your Olight M22.
I have around 85 lights now in many different brands and only 4 or 5 of them have came with a heavier lanyard , no matter how large or how small the light itself is or the brand of light it is. Those that are heavier (nicer) lanyards , have the clip on the end. The thing with those is that they wear off the anodizing , so if that type of lanyard with a clip is supplied , then many people would be upset that their $200.00 light is getting scratched or having anodizing worn off from the metal to metal contact where it attaches.
It is really a NO win situation for any of the companies , as there will be probably be complaints no matter what they supply because everyone has their personal preferences.
I personally don’t use many lanyards , but the ones I do have attached to just a few of my lights are attached in one of 3 ways………
1. I cut the little string completely off (like the one you have that broke) and run the heavy part of the lanyard itself through a split ring and attach it to the light.
2. I use the metal clip style lanyard , if the hole on the light is big enough to accommodate it , and attach that directly in the hole.
3. I use a split ring in the lanyard hole of the light and attach the metal clip style lanyard to that.
The pictures below show the 3 ends or attachment methods I would use , with the first picture using a lanyard like the one you have that “broke”. I really don’t see any of them breaking or wearing through , nearly as easy as the little string , even with the biggest of handheld lights out there , when attached in one of these ways.
LMGTFY:
https://www.google.com/search?q=cutproof+lanyard
A variety of choices. They’ll cost you a bit more than you paid for the flashlight.
(These are made to prevent a thief cutting the strap and running off with your precioussss, or your arborist saw cutting through it by mistake …)
This is just not looking that the lanyard is weared out
A 5 cent steel ring and there is no problem in the future
Get you some 1.5 or 2 mm DYNEEMA and call it a day.
Just don’t wrap it around your wrist if there is a chance it or your light might get hung up on an object large enough to drag you. Cause it will rip your hand off before it will break.
Thanks Teacher, you just cost me $40!
Marlow D12 Max 78 at 3mm is a black cord with a 3300 lb breaking load! Yes, a 1/8” cord with a ton and half capability! Rip your hand off, yup! Got some coming, now I have to learn to splice cord. lol
This sailing supply site likes the high end shipping options. I started not to buy because of that then realized even at some $2.00 a foot final cost it’d be some really cheap lanyards that would hold up exceptionally well. We’ll see how that plays out. I bought 20’ of this one. A 10mm cord could be used to tow a car for pete’s sake! (over 20,000 lb bursting strength on the D12 with SK75 Dyneema. Astonishing! Higher grades are much stronger of course.)
No problem my friend… anything to help further our collective obsessions.
Yeah ‘DB’ that stuff is very expensive but it is amazing, to say the least.
Check out some of the breaking strengths on this Chart of Mooring Lines made of DYNEEMA by Samson Rope. Unreal!!!
You can probably pick up some “splicing tips” on the Samson site too.
Check out the video Why Splice first off.
And yeah, this is not something you would want tightly wrapped around your wrist in the form of a lanyard or use as a necklace unless it had a breakaway release. Otherwise you would be an injured or dead duck in a ‘hangup situation’.
Of course that probably applies to other products as well.
Which brings us full circle, back to the OP’s “issue”. Could it be that they intentionally use the small loop at the end of the lanyard as a safety release of sorts? Purposely sized down so it will break before too much damage is done to the user in a hang-up situation?
Very possibly so. :+1:
Kinda off subject, but several years ago in my town there was a city worker that was riding in the back of a truck with a flat dump with sides on it. They stopped to pick up some stuff on the side of the road and when he jumped out his wedding band caught on the siding and he hit and broke his neck. Killed him instantly.
A freak accident, but it goes to show that things can happen fast and unexpectedly.
I worked at a lumber yard and made deliveries to building sites for many years, drove a 20’ flat bed truck with a dump bed. There were stake slots and a protective band around the entire bed. Once I had a large load on the truck with various building materials, I’d gotten on top of the load to secure chimney flues and fire brick and in jumping off my toes caught in that protective steel band around the side of the bed. I pivoted down and did manage to get my hands up to catch myself but still broke a front tooth out, chipped my glasses, and broke my right elbow. It was like lightning, so instantaneous. So yeah, I know how fast things happen.
Maybe a 3000 lb strong lanyard isn’t the best of ideas, I have some 50 lb test Spiderwire I can tie the lanyard onto the light with, that should give a measure of breakaway while still being rot, chemical and abrasion resistant.
I helped out a buddy of mine who wanted a small light to EDC at his job as a ride mechanic at a popular theme park .
I ended up getting him a Thrunite T10 . I put a stainless split ring through the lanyard hole and made a short lanyard out of elastic cord . He was able to adjust the lanyard until the cord gripped his wrist just enough to keep it safely fastened while on the job . It also allowed him to grab it and use it quickly .
I have given him several feet of the elastic cord and he told me he has replaced the lanyard a couple of times in the past couple of years .
So for a small , lightweight flashlight , elastic cord is another option .
You gonna give us some paracord tying lessons Jack?
If ever there was a Master
With cord or string or rope
It’d be Jack the Clipper
To give us all some hope
With snakes and leashes and lanyards
All made by sleight of hand
The most popular way to carry a light
Is a custom from Jack the Man!
Sign me up for the 101
On Tying up a wild lumen beastie
The last thing I need is to see a fav smash
When the cord fails from being all yeasty. (ewwww!)
Um , thanks for the tribute , Dale .
I wonder how many of the lanyards I made and gave away here are still in use ….
I’ve never trusted those thin buggers- they’re certainly not up to being used as a carry strap; perhaps they’re more a safety-strap if you lose your grip on a light And if you’re dropping your light that much then shame on you!
Phil
