NiWalker Vostro Black BK-FA09S
It’s always nice to learn something new :slight_smile: , thank you for clearing this up :beer:
On lights that use a boost or buck converter the voltage drop under load decrease the total power availiable, so high drain cells gain some Wh over low drain cells
Lets say the LED and driver need 30W on turbo
A 18650GA cell gets like 0.15V less drop over a protected low drain cell like 18650B
So 0.15Vx(14Ah)+3.6Vx0.4Ah=3.54Wh more energy
So 7 minutes more runtime
I just got my BK-FA09s this morning. I tested it for lumens against the K70 and got 2565 lumens for K70 and 2520 for FA09s. The reflector dimensions appear the same between the two. The K70 head is wider though to accommodate the extensive thermal fins. The FA09s is a wee bit less cumbersome. The FA09s has much more neutral tint, maybe 5,000k, and much nicer in that specific regard imo. In initial testing, I wouldn’t shy away from BK-FA09s if I was considering a K70, especially if I like neutral tint.
2520 lumens… Niwalker keeps on impressing me… And the price… Just nice :wink:
Would be even better if we could get a discount code for it from somewhere.
I had bought a K70 several months before with a coupon,at a very good price,but this door is closed now for ever.Unfortunately.
Now 159.95$ at hkequipment, i remember it being less than that (wasn’t it something like 129 ?) last time i checked :cry:
Yes, introductory was less. When I saw it, I think $134.99 and used a 1x 15% ebay code for 114.7 from HKE. A week or two later it was $159.9 any and everyplace. I got lucky. So far though, it looks like a nice NW alternative to the K70 which is $179. typical.
I know that Martin has a deal for the BK-FA09S,but I have both a K70 and a TN42,so I pass this one.
Yep me too, but IF it was a E-switch light, I would of snagged one up! :+1:
Are you still digging the BK-FA09 ?
Recieved mine yesterdy :expressionless:
Wow, this is a real lightsaber compared with my Olight SR91 :+1:
I must say that I recently picked up this hobby after a few years and the only thrower I can compare with is this Olight sr91 :wink:
First impressions, nice light and the magnetic power ring does the job nice.
Light came with a little humidity inside the reflector? So after drying no signs inside the lens when power up.
Battery carrier is the most fragile part I believe, put some Efest IMR 3500 mAh inside and this is damned a tight fit :rage:
Had even to tighten the screws that holds the battery carrier together.
Wonder how long this carrier hold together, also you must be very cautious when removing the battery’s you don’t dammage the top of the battery!
Springs in the carrier are very thick and stiff.
Overall very, very impressed by the performance of this light!
got mine too and totally agree on all points!
i think i change the springs to thinner ones
due to the 4S i am not afraid of high Amps
+1. The holder is a battery vice. I saw on another forum a pic where someone’s carrier simply busted apart when they were trying to get the cell into it. It’s not what’s mean by tight tolerances. :frowning:
Does this light step down? If so, how long can/does it run before having to do so? And can you tell when it does?
It has a temperature controlled step down, I would say it steps down to approximately half output, when the temperature has dropped it steps back up to max again.
+1
:beer:
How long does that take to happen?
depends on the surrounding Temp / Wind since its a true Temp-regulation i´d assume
I got mine in the post today and a quick temp/lux test was the first thing I did.
The light was sat in my bathroom with no airflow. Around 7mins30 it decided to drop down to the next lowest power. I didn’t interupt it as I wondered if it’d come back on its own - it didnt. I turned it down a mode and back up, nothing. I turned it off at the bottom switch and back on and it was back to full pelt.
Vostro Temp Lux
0 20 295
1 24.7 288
2 29.7 281
3 33.3 277
4 35.8 274
5 38.7 271
6 41 267
7 42.6 265
8 44.5 137
9 43.8 140
10 42.9 140
