This was a $1.75 light off ebay auction. Advertised as 12W but only drew 4.7W. Swapped all the beads to 3W WW 4000K and stuffed one of those 20W Flood light drivers into it. Had a few drivers and first used one I knew was going to deliver 20W. Ran the light about an hour and just thought it got too warm. Dug out another “20W” driver and gave it a test. 12.4W and it really is not noticeably dimmer than it was at 19W on the other driver. These 20W drivers should deliver 600mA with voltage between 24-38V DC, so the 9X 3W fall into the range.
This light has good bones… Good fins, good pressed in shelf for the board with descent thickness. Used a moderate anount of thermal grease spread evenly. Locked the shelf and MCPCB in better, 3 screw holes that were not originally used, with some Stainless metric socket head screws and washers… It’s tight now. There is also some added pressure from the outer bezel on the optics.
Not sure where I am going to use this but it was something to do today. Confident it could run 24/7 without issues.
I modded an Ultrafire S5 some weeks ago , with a Nichia 219C 5700k 80+ CRI on Noctigon , flashed biscotti on a 7135x8 driver that i installed , and changed reflector for an OP reflector from Convoy S2+ .
One great light for 10$ …
Now i have still to mod the one you did too , i just have to get some Nichia’s (probably 219B) and some 16mm DTP boards .
Glad you saw the post. Was thinking of sending it to ya.
Wish I could program a driver… Still learning basics. I was proud of the resistor mod on that one because I was flying by the seat of my pants and generally copy what others do on electronics mods. May do 2X 1R0 stacked on the next. 0.25 ohm may still be under 2A, shooting for 1.5A to be safe.
Eagle Eye X7 XP-L HI 3A got some boost today. Killer 26650 light IMO.
MtnE 20mm Fet+1 and bypassed SW spring. Didn’t check amps because the tail switch assembly ring is difficult to get started and scratches get worse on the tail finish.
Stripped a flashlight, that is. I got this grey S2+ for like $6. But upon getting it, I couldn’t stand the color so it’s sat in its box for a month or so.
But I got inspired by vwpieces to strip and polish it. It’s not perfect, but much better than that ugly grey.
I like it. :+1: :+1:
Mine WAS Blue. Got it for the metal SW but couldn’t take the color any more. Tried to bake it and really got ugly, not changing color. So I went bare naked.
Most of the time I take pics of a polished light and see that I need to do-over. Back to 2000 wet and usually harder polish cause it’s late and frustrated. Worn 2000 paper will help also.
Grease the threads, and I usually wipe a thin coat of oil inside. Sometimes the Lye is not rinsed off good enough and white oxidization forms in a few days.
I really like the metal switch, but that’s OK. Having the silicone one on this just means that it’ll get an illuminated tailcap soon. I’m thinking white or white & blue on this one, should go with the bare metal nicely.
SF348 got a new emitter. Yeah, another 219B 4000K High CRI.
Cleaned up the pill, removed burrs and flatened best I could. Opened the reflector a bit too much and got a couple scratches, but oh well it fits the emitter. There was no thermal paste on it. reflowed the emitter to the original 8mm aluminum MCPCB.
Bought it cause it was $4.50 but never used this light because it was an awful color. Now I may grab it on occasion.
Got tired of the SF348 screaming “Polish me, Polish Me!” Hope the voices will stop now.
more incremental work on my “scratch build” DIY-USB microscope project…
melted zinc, cast it in into a short piece of round stock, 3 or more inches in diameter… for inexpensive “practicing” making the general shape of something i will make later out of aluminum stock.
practicing the shape on aluminum would be cost prohibitive, lol…
