Hi,
spacer for the Convoy C8 arrived and fits perfect. I put an 34mm x 1.5mm O-ring on top. The light is pretty heavy now
Regards
Kenjii
Hi,
Regards
Kenjii
I think you are one from those who can fit any part to any build and they anyway will fit perfectly. In fact I have made some mistakes and this samples have little wrong dimentions.
Your photos are great as usual.
Everything fits … somehow
This is a great looking C8 Kenjii. What optics and MCPCB did you use for this build?
As you can see pcb and optics are same to X6 triple (xp32+Cute-3).
Now I see it, thanks. Not much experience with TIR optics from my side, sorry.
I just finished my new build using that copper rod that you sent me. Great stuff, thanks again Kiriba .
Candy Apple Red C8 Triple Nichia 4500K’s
Received S2+ copper pill and carclo optic. Very well packed and fast shipping. Thank you.
I will ask those who are interested in VG-10 quad to open your hosts and specify which version do you have:
2)
Medium version from amazon deals. Head is machined inside, o-ring around glass lens (between bezel and reflector). Bezel have rim so glass enters inside bezel.
3)
Epic fail version from thorfire GB. Extra aluminium disc and LB pcb under main pcb.
Lol, I have # 2 and @#$% 3. Are you makings kits for all 3?
№1 and №2 have same spacers but different liners.
№3 fits spacer from M2 and (I hope) one from two first liners.
I think I will start with №1 just because it will be tested sooner than others.
Got some spacers last week. Well packed and fast shipping, everything fits perfect.
Thanks!
Big size rod in stock, dont miss oppotunity to order custom spacer for SRK clone.
Interesting…
Can you link me to details about this?
Will this be to run triples with carlco optics in a SRK?
No-no, I will provide meteor-style set for Q8 when it will be ready.
Now I mean just simple disc to fill empty place under pcb in cheap SRK clones.
ok, no prob. Just found my SRK the other day and was mulling over ideas for it.
C8 aluminium kits are in work. Until I havent used all 35mm aluminium rod for C8 kits you can say if you want to have X6, X7 or F13 spacers made from aluminium.
Copper rod for Courui pills is ordered. Please give me suggest where else it (OD 45mm) can be used.
C8 sets will be available in a week. Price will be $11 for set from al spacer, al liner and gitd o-ring. Still have some XP 32 boards, A6 drivers, lightened tailswitch boards. Cute-3SS optics will be stocked in the mid of April.
I think I will make limited quantities of rare parts, so if you need Courui D01 copper pill, please let me know asap.
I have #3 the @#$& version. Actually the first light I “built” I cut and sanded a piece of spare copper as a spacer. I would like a professional built spacer for a triple though lol.
My custom spacers arrived quickly, well packed and marked. Thanks again!
- old version from one of chinese websites. Head internal surfaces are complete anodized (no shiny machined surfaces), o-ring between reflector and stock glass lens. Bezel is flat from bottom.
Is this the No.1?
