This switch was chosen because better water proofing
The light is a bonus Thorfire put in.
And they must like the beacon function a lot since they implemented it in the S70S
I have a question about the size. I know, I could do a bunch of research myself and find the answer, but maybe somebody could answer it easily and save me lots of trouble. Compared to “standard” sized SRK style lights, is the head of the Q8 a larger diameter, or the tube smaller diameter, or both? Because SRK’s are tube style, meaning there is not a head that is bigger than the body, rather all is the same diameter (Edit: or very nearly the same). I like the look of the Q8, so this isn’t a complaint. I’m just curious about the proportional size(s).
The head diam. matches a few SRK clones I have, so the head diam is definitely standard. As far as the battery tube goes, it's probably narrower because the classic SRK has these machined railings along the body with holes to secure a lanyard on. Those are eliminated in this design. If you look around though (like on eBay), the "new style SRK" looks very similar to the Q8, in that the battery tube is void of railings and has knurling. I like the new knurling style, both for looks and feel. Dunno who came first - the Q8 or this new style. I posted pics of my gold 12X SRK a while with the new styling:
Clearly on this one, the head is wider than the body/tube, but pretty sure the head diam on this one is also std size.
Yes we took the widest finned of SRKs
But instead of just a few fins and then a narrower head the width of the Q8 head stays fatter to accommodate more mass and fins thus better cooling.
Post #3348 and post #3390 should answer this: ~5,600 lumens. Our official line has been 4,000+, but as you can see, proto #1 did much better. Also, add ~400 when the springs are bypassed, maybe another ~400 if using SONY VTC6 cells. Proto #2 has double springs, so we should see higher #'s stock (no bypassed springs) than the stock proto #1, but all depends if other changes have impact.
This is all based on my very unofficial PVC based lightbox, but I've done a ton of light measurements with it, and seems to be in the ballpark of accuracy.
I looked at the pics carefully, comparing to proto #1 in hand, and I'd say the reflector is identical for the part we can see in the pic (top view). Dimensionally, the reflector cups look identical, and the cup wall separators look identical as well. Yea, I was concerned bout that as well.
Also looks like the LED alignment pieces are the same (round), and the underlying MCPCB is still white, but could be the LED's are centered better, hard to say for sure, if #2's are perfectly centered though - still look a little off. Honestly though, even with off centered in #1, I can't tell by the beam or output.
