Hey, that’s not very expensive. I think I’ll pick one of these babies up. Thanks.
There is a coupon from m4dm4x too .
JasonWW: giorgoskok:Even with a multimeter & 16awg short leads i wasn’t able to get correct readings .
I only use clamp meter now (uni-t ut210e) .Hey, that’s not very expensive. I think I’ll pick one of these babies up. Thanks.
I can’t find it. I saw one from Freeme. Is that who you were thinking of?
Any news on the short tube? Still hasn’t appeared in the Convoy store.
The short tube is listed now. I’ll add the link to the L2/L6 modding thread and the OP here and in the L2 thread later with the additional details.
https://www.aliexpress.com/store/product/L2-L6-short-tube/330416_32803828707.html
Hi Djozz, which batteries do you use? My L6 is from fasttech and with r100 and fresh liitokalas this at 7.1 amps + - greetings.
I will do another measurement, I use the same 5000mAh Liitokala’s.
Well, try sanyo ga, kill two liitokalas doing shortcut, a stupid mistake on my part :person_facepalming: , with fresh sanyo drain very fast, start above 7.3 amps and immediately start to go down so this battery is not enough for Feed the modified L6 but it serves as a sample, greetings !!
I fully charged the Liitokala’s, used a thick magnet between the two batteries because they are so short that they do not really push on the springs very hard, and it is much better: 6.6A using a small copper coil with clamp meter with the tail taken off, and 3800 lumen at 30 seconds with the tail in place.
This is with the added R110 in parallel.
Maybe magnets, produce resistance? R110 less than r100, that may be another difference in performance
Some magnets are coated with a protective layer. Even if it isnt, there may be a little resistance in it. I use solder blobs on my 2 liitokala that I use exclusively in the L6.
The 2 stock R082 resistors create 0.041 ohms.
Adding a R100 drops it to 0.0291
Adding a R110 drops it to 0.0298
So pretty much the same.
lumiere:Any news on the short tube? Still hasn’t appeared in the Convoy store.
Page Not Found - Aliexpress.com
then when i use it in L6. can i use 1*26650 ? or use for 3*26650?
I thought the purpose of the short tube was for fitting 2 x 26350 cells. Right? Wrong?
… making for a shorter easier to carry light, though with a reduced run time.
I thought it will have the tactical ring
Yeah, it was supposed to actually but that slipped through the cracks on this first run. :weary: If/when he does another run it will have the threaded rings.
Heyhey,
Got my smooth reflector for the L6, but damn that’s an ugly beam now. Does it get better when you shave the dome, or even worse?
Heyhey,
Hahaa!! A little Ringy is it! Better/Worse? The Answer: It’s for those who know and you to find out!!
smo reflector begs for xhp70.2
J-Dub74:Yeah, it was supposed to actually but that slipped through the cracks on this first run. :weary: If/when he does another run it will have the threaded rings.
Thanks! I didn’t see that.
Heyhey,
I’d say you have the same beam pattern, it’s just more intense. Why did you buy the SMO, I hope its not for pretty beam shape. Lol
It does give a big jump in lux and distance, but you have to play with the distance from the emitter to get a smoother hot spot.
I’m kinda digging my shaved dome xhp70 with the OP reflector. It’s definitely a tighter “pretty” beam. Still has improved throw, too.
My xhp50.2 should arrive any day now and I’ll try it with the SMO reflector.
JasonWW: J-Dub74:Yeah, it was supposed to actually but that slipped through the cracks on this first run. :weary: If/when he does another run it will have the threaded rings.
He responded to this same question on the L2 and L6 mod thread. I just copied it here.
