1. no i havent determined how to dissamble it. i dont know how to do it.
2. this post may contain some relevant graphic detail: head disassembly
3. i bet my burro head that the E09 head is a one-piece. i've looked at it under the loupe and there is no seam. With the Quark head, yes, the Quark head is a two-piece. but here with the E09, no, the E09 head is a massive one-piece.
PWM is also visible if i move it very fast, just like in the photos posted above.
When measuring the amps on a circuit at only 1,2V the slightest voltage drop over the amp-meter will affect the measurements.
23 minutes runtime on a 800mAh battery (confirmed in the Maha charger) means it pulls even more than 1,67A out of the little battery on high. An alkaline AAA battery will probably not be able to produce such high currents, it seems to be a little bit brighter on nimh's.
please could you guys take a photo of the setup? i might be getting a kickass digital multimeter but i wouldnt know how you connect/wire the E09 head with the multimeter and with the battery.
i mean.. the head of the E09 is so tiny!! Are you using magnets at the tip of the wire?
Please some photos, i need to see how ampere measurements on AAA (and AA) flashlights are done! Thanks for some help here!!
Just a little note, DD has raised the price on it ONCE AGAIN, yesterday it was 12.99, today already 13.99, although 12.99 should have run for another 4-6 days according to their offer timer near the price, wtf ?!
I guess no matter how good this thing turns out to be Ill have to wait for some discounts in the future, no way I am buying this for more than initially advertised price that you guys snatched this one for.
Me and my friend managed to place one order and were planning on getting more. Too late now. With reports of pwm when it is supposed to be CC, I think I'll just spend a little bit more and get a better light.
If I were you, that's what I'd be doing. To be fair though, I originally bought an E09 from MF for $14 and change and I feel it's still a good value even at that price. That's why I ordered a couple more from DD when they could be had for cheap.
Guys, DO NOT DISASSEMBLE THE HEAD. the alu reflector causes a short on the LED pill.
originally the reflector is "glued" to the LED dome. The glue is the insulating layer so that the aluminum of the reflector cannot bridge (short) the contacts of the PCB.
Any idea how i can insulate now??
Why am i asking?
Effectively, both of my samples have stopped working. They still work in mule mode, i.e. with reflector head off. As soon as i screw on the reflector head, light off.
Truly big thanks for taking the hit for the team (apparently both barrels). I will follow your advice and will not disassemble the head on mine. Hope you find a way to re-insulate.
