Nice write up. Great detail and good photos.
If later down the line you want some extra wow then drop in a dedomed/sliced XPG2/XPG3.
The G2 will require a regulated driver (qlite is a good option) whereas the G3 should be able to handle short bursts of direct drive if well heatsinked and will be able to put out ~900 OTF lumens but being a smaller die it will out throw any XML or XPL.
There was some machining marks including a dimple in the middle, but overall the shelf seemed pretty flat. I didn’t notice any unevenness between the LED MCPCB and the shelf.
Okay… luckily my wife had a pair of round-nose pliers for jewelry crafting and those worked although it did still take a bit of torque to break the retaining ring loose.
However… now I have another problem. Unlike your pictures and the video that I watched, the driver is not loosely in there. In fact, it almost seems like the driver is wedged in there somehow. It’s like the driver is “set” perfectly inside. It’s solid contact all around the diameter of the driver. I tried pulling on the spring a little bit but the driver does not budge AT ALL. Any ideas? I don’t want to wreck the light.
This is the video I’m referring to. In that video is seems like the driver is loosely in there once you remove the retaining ring.
When I removed the retainer ring on the head, like in the video, the driver was not stuck at all and pulled right out. But when I put in the new driver, I had to file down the sides in order for it to fit. So maybe the driver in yours was a little wider and wedged in when the retainer ring was put on. If it’s not budging, you could take out the screws holding the LED and push through the holes with a tooth pick. Or if you are replacing the LED, you could push through the wire holes since they are bigger.
I think this happens when its been in a light for a long time. My ee x6 did the exact same thing.
Try after removing the ring and desolder the led wires. Try to use the wires some to push the driver back. A little of that and tugging on the spring it will come out. I’ve had to play with them to get them out before. Sometimes it helps sometimes it doesn’t. Try that and pulling the spring a little harder. Or take a tooth pick and try to pry the driver a little bit or stick down the wire hole for a little push. Push with toothpick pull by the spring
I don’t think its to warm it definitely not warmer then my v6 3d xpl c8. Its intense though at 50 yards the beam is maybe 3 feet across.
I guess it depends on the led as well. I have xml2 u4 1a and 1c that ended up really warm. And a xpg2 s4 0d that warmed up a good bit. In the sweet spot. The xml2 is bordering to warm but once you use the light for a few mins your eyes adjust and get use to it. But the xpg2 s4 2b. Looks cooler then the xpg s4 0d after dedoming strange but that’s what happened. If you like warmer go for the 0d dedomed
I actually don’t mind warm…ish. Figured most people dedome 1As and the like, so starting with something a bit warmer might end up even warmer than that.
It usually does I’ve seen 3d dedomed and i don’t like it at all. If I had to guess. Id say it came out around 5500k if 3d is 4700-5000 looking at the two of them. Its not blue and its not exactly neutral. I think you’d like it. The 0d looks more similar to xml2 dedomed just a little less lemon color.
I like it a lot though, use it just to use it even though not right for the task at hand. The racoons and possums hate it. I strobe them with it. Had two on the porch last night trying to steal cat food. The racoon I can shine 50-75 yards away and it runs. And if it’s on the porch it hauls ass. But the possums man those things can be nasty and when they get pissed its not nice
I kinda lucked out with all my dome-on chips. Dedoming is always rolling the dice, I know.
As long as they don’t turn green. Just got a bone-stock Zanfare F1, and man is it an ugly green. Pea-soup green. Ecch. Ugggg-ly.
I tend to leave ’em alone. I put out catfood for the stray critters that took up residence a while back, and if I leave it, the ants and flies will get it. So this critter comes around and practically licks the plate clean.
Of course, he uses my patio as his own personal toilet, but…
This one just kinda hisses/growls when he doesn’t waddle away and instead gets cornered. I’ll pet him and get him really pist at the degradation, but hey, it’s fun.
Oh, and they fluoresce red under UV light.
Eh, they only live 2, maybe 3 years, so I’ll be nice to him.
My Convoy C8 died the other night while I was navigating the river. Since Mountain Electronics is out of stock on new Convoy C8s I think I will spend the same money and do this with the body.
I appreciate the step-by-step and detailed pictures. I am still at the “push button, light comes on” stage of flashlights, and your thread makes going beyond that point seem easy.
I’m interested to see what the difference will be.
i just spent an hour trying to remove the driver retaining ring from my C8, the ring is now destroyed and probably unusable. far out its in there tight! anyone know where i might be able to get a replacement?
