1.88A at the emitter at 13.97Vf. Difficult to get read on the cells for current draw.
Two cells positive down, one cell positive up. One of the bays is set up such that the light will work on one 18650, or two CR123, in an emergency. Slightly lower output and of course less run time. Nearly 1500 lumens on a single 18650 where it does 2114 at start 2038 at 30 sec with all 3 cells installed. (Sony VTC6 with added button top)
Anybody here know how this is done? The 3 cells are joined at the tail cap by what appears to be a pressed in steel disc. There is a momentary e-switch in the tail that has a corresponding contact pad on the spring side and the tube has a spring loaded brass plunger for this momentary switch, so the light works the same through either momentary, side or tail. So is the light using all 3 cells and a Buck configuration? Or does it ignore the single bay and do a Boost on the two cells? In the below pics, it’s B1 that works as a single cell, you can add B2 and B3 for 3 cell configuration which is the default way to use the light.
The retaining ring has an inset shelf on the inside that captures the tail pcb, it’s loose so it can freely rotate. Worthy to note that this retaining ring is left hand thread…
The electronic features of this light seem well thought out, it’s driven right up to it’s sweet spot, or dang near, and is easy to use. Wish they had reversing on the switch action but oh well, ToyKeeper has me thoroughly spoiled in that regard.
Interesting batt configuration.
I think It is Boost driver.
B1 boost to 13V± for sure.
B2 and B3 are in series 8.4V to 13V± ?
Dale can you use 2 cells only in B2 and B3 slot ?
Are there any reviews out there for this light already? My searching seems to throw up group buys and random YouTube videos but I can’t find any decent beam shots / comparisons.
I got one in the post today and I need to do a review on it but I’m not sure if it’s as bright as it should be.
Side by side against my TM16GT at the length of my road the TM16GT is noticeably brighter.
I need to get some beam shots of a few lights but even at 11pm it’s still not totally dark out.
