New 4XP Noctigon MCPCB for quad optic
I tried that, set up a jig and managed to pretty cleanly shave XP-Lā€™s to the same measured thickness as the HIā€™s. They bin them though, so you get a more consistent end result. Notice too that the HI power bin is well below the top XP-L, so youā€™ll get more downrange punch and a tighter hot spot with a de-domed XP-L than with an HI, thereā€™s that loss there with the HI even though the tint is better. So itā€™s about compromise, as usual.
I used a V6 1D for the output, itā€™s making 1486.95 which is good, but could be better. Heck, Iā€™m getting 1504 lumens at 5.13A in the little Copper X5 on an Efest Purple IMR14500 with the HI they put in there. I did spring bypasses on a pair of A6ā€™s for a forum member, different tints, but both made 6.18A at the tail. Donā€™t see that very often these days!
Cree XP-L V6-0D 450LM 7000-8000K LED Emitter
Ohh - you used the 1D's then. Hank just emailed me - the 1D's are out of stock, but he's got V5 0D's. Oh well....
Ahh, yep - could be V5, could be V2 - who knows. They dunno what they are selling. Not that I wouldn't buy them though, the sucker that I am Smile.
Hello, special discount for the XM-L2 LED, including XM-L2 U3 3D, U4 1A, T6 4C,
get them while stock lasts.
And the Noctigon XM16, XM20 MCPCB.
Get them until stock lasts!
Hi Hank,
I see that there have not been new items on your site for a while now. Are you closing business at some point? That would be a pity.
:beer: , Jos
Well, thanks for your concern, weā€™ve been working on some new projects, and they will be released before the end of this month.
some small leak:
D1S, 128mm length, 50mm head, side switch, 120kcd.
D4, 92mm length, side switch, 10622 quad optic
D1, D17 will be coming later.
^ :partying_face:
July 2017 will be ramen month.
OOH, goodies! Thanks Hank! :+1:
Iā€™m proud of that this handy D1S can throw 110kcd.
ā€¦ Curious whether these lights are branded as Noctigonā€¦
The shorter, the smaller, the brighter, even 0.1mm matters
With 92mm length, Carclo quad 10622 beam pattern, I pocket it every day.
Nope, a new brand
Iā€™ve only had two single 18650 lights: Fenix TK11 XP-G R5 (old), and Tiablo A10G XR-E R2 (old). Thereā€™s literally not a single 18650 light that excites me for EDC purpose. Until now. Man Iā€™m stoked. :smiley:
Nice lights :+1:
In that case my guess is that it does not have a (BeCu) spring for the cellā€¦ Although I donā€™t find the design elegant, DQGā€™s design used in the Tiny 26650 is clever.
It does use our BeCu spring both in the tailcap and driver pcb to minimize
the resistance as small as possible.
I did not expect such a positive answer, that is great news! :slight_smile:
That D4 seems one of those perfect flashlights, I hope for a user interface just as perfect as the form and specs!
Interesting. I do prefer springs over some solid contact so thatā€™s good to know.
The D1 has one emitter. The D4 has four emitters. Soā€¦ does the D17 have seventeen emitters? The planned 8x18650 powered Noctigon was I believe supposed to have 9 XHP35 HI emitters for 16000 lumens. Perhaps this changed to seventeen XP-L HI emitters? Or maybe seventeen XP-G2/Nichia emitters for around 10000 lumens, but with a lot more throw than the M43?
