to get the 3 channel modes to match the manual you can add the 5 modes,
I am sure some more code lines need to be changed to get it to 12 from 8 modes
of course if people want to adjust the modes for their lights to match they have to edit the values for the channels,
but at least the modecount should be the same on all version
Yea, that's what I'll do - add the mode sets for the triple configuration to get it back to 12.
I pm'ed you and The Miller about the mode percentage definitions. It's sort of a big deal for the Q8 -- dunno if it makes a big difference but the the % values are all off considerably. Hoping to just update the manual for the Q8 (separate manual from the NarsilM manual).
BTW, when the Q8 code is completely finalized, could you save a copy of what was sent to Thorfire? I’d like to keep a snapshot of the exact release code in the repository.
UTorch UT01 has that special engineer mode, where you can set your moon mode by selecting from a selection of three different level options in each of the regular modes, very neat to be able to set your moon all the way low or up two slight increases and then go on to the next regular mode and choose out of three levels there as well, and as it is for each mode in that light, real fun, this UI is just spectacular reading, sure would love to use it.
Possible, yes. DEL has a board specifically designed for the L4 though, 2 channels, though not sure of zener/LDO support. I assume you want a zener, not LDO for some reason.
Yes I wanted to use one I already have, if I can. 2S Zener mod fet only 1 channel 26mm TA. Can it be done? I have no problem air wiring a pin if need be.
Boy, just don't have time right now, but it certainly can be done in firmware, fairly simply I believe. TA puts the FET on pin #3, normally it's on pin #6 for single channel or two channel drivers. So it's doable - could re-assign the pins, build NarsilM for one channel, and good to go. It would have the ramping table and mode sets. Not sure how they all would work out for you, but they can be tweaked as well.
Might need some code mods, not sure. The single channel config for NarsilM is set for pin #6, FET or 7135's.
Also, I tested it a bit… though I made no attempt to test thermal response or the indicator LED (I have none).
I don’t think I found any important bugs, but here are some possible smaller bugs:
Ramping UI:
After version readout, another double-click appears to go to turbo? (then another double-click to strobe) Sometimes instead of turbo, it’ll blink once at maximum then turn off, and a double-click still goes to strobe afterward.
Moon is separate from the ramp. (might be intentional?)
With moon set higher than default (PWM=7), I see odd behavior during long-press-from-off: It comes on initially at PWM=7, but if I keep holding it, the light drops to a lower level and ramps up.
With moon set higher than default, I can still ramp down to PWM=3, even if it’s lower than what moon is set to.
With moon set to PWM=1 or PWM=2, moon can’t be memorized because it’s below the bottom of the ramp.
Mode Set UI:
Blinkies can get kind of “stuck”. To make this happen:
Short-click then click-and-hold from off to enter battcheck mode.
Turn the light off.
Double-click. It should go to level 2, but instead it starts blinking out the temperature.
Undocumented: After a steady mode locks in, a quick click then click-and-hold goes to turbo. (off then reverse, really)
The main things I’d change are some of the mappings from UI actions to state transitions. Those aren’t important, but here are some ideas:
Ramping UI:
Instead of double-click from turbo to strobe, do double-click from turbo back to the previous ramp level. This way it’s double-click to enter and double-click to exit.
Instead of triple-click to battcheck, do triple-click to strobe and quad-click to battcheck. This makes strobe immediately accessible from off, and puts strobe and battcheck on the same actions as Zebralight.
Instead of quad-click to lock-out, do five (or maybe more?) clicks to lockout.
In blinky modes, hold the button to navigate forward/backward through modes. Reverses the same way as ramping.
Mode Set UI: No changes.
Other: Possibly add a Baton-like UI which uses the Mode Set UI settings? Basically the same as Ramping UI, but with discrete levels instead of a smooth ramp.
Darn, quoting your post mangles it up badly.... No time to fully respond right now but you got some very good points there, excellent feedback!!
Looks like might be 2 bugs and/or some unintended behavior. Other things are behavior as intended/designed.
Agree - the moon mode custom setting has some quirks to it, and how it's related to ramping. I was always well aware of it, just didn't get into working/thinking out something better.
But, really really like some of your suggestions - dang, might have to work on those real quick, but having no time right now.... Really like your suggestions on the 2X+ click changes... Not familiar with the Zebra UI - would be an advantage to have some consistency there though with it.
If the driver is wired to put the indicator LEDs behind the Zener/LDO, or the indicator LEDs otherwise have the right voltage going to them, I’d expect it to still work on a 2S/3S/4S build. They might need somewhat different resistor values though, in either case, to compensate for higher voltage.
I'm pretty sure I got triple channel NarsilM 1.0 working fine with a Ind. LED. I have it installed now, from June 1st or so, in an OTR M3. It's got the delayed dbl-click, all the features of NarsilM 1.0 and uses TA's triple with 3 7135's as the bank:
Hhmm - is the stepdown in mode sets? Is this still a problem? I'm gonna be working on this feature for the BLF GT, at least add the option into NarsilM. Plan on setting a max of like 80-90% for ramping, but still allow the dbl-click turbo to go to 100%.
It looks like you are talking bout mode sets, not ramping. Sounds like you didn't configure it correctly, but not sure. Think I already had a factory set of modes that didn't go to max output and I recall it worked fine.
