Thanks that looks interesting. Also T18’s shrink wrap idea. I totally agree I’d prefer if it had some knurling.
Here’s another idea for grip, Vape Bands!
Very grippy silicone rubber around 23mm dia. they fit the S2+ great.
Just one of these near the tail end of the tube works great for a tactical grip.
The D4 has a pretty thick tube: 23.9mm(spec from TK) I tried one on a flashlight head that measured 23.5mm and it fit no problem.
You can get a lot of different colors, and different widths (thin or thick) FT has tons, search “vape bands”:
Ceilingbounce works great for what it does. It has been immensely helpful for this project. But if I want to measure lumens, I have a calibrated light box.
It definitely beats trying to estimate lumens based on the relative placement of pixels in a graph.
In any case, I got 1500 by guessing 4300 for the peak value (not the 100% value) and scaling it by the relative position of the stable state on the graph. I got 2250 by putting the light in my light box during a similar test. The main difference was that the graph was fan-cooled, while the light box test wasn’t cooled at all. And one used a calibrated and reasonably trustworthy sensor, while the other used whatever cheap thing was good enough to auto-adjust screen brightness in sunlight.
There’s nothing wrong with Ceilingbounce. My phone sensor probably just has a non-linear response curve.
That’s what I was looking for. If that’s common enough, it’s an issue I should at least make people aware of, as it could result in inaccurate information like “this light has a stepdown to 40” when it’s actually 60.
One of my phones is sensitive to CRI, giving significantly higher readings with high-CRI lights. I wonder if I could use that as a crude way to estimate CRI….
I’ve used Talon myself and really do like it, mostly on handguns and actually was where I got the idea for covering and coating lights that have some issue, you can start here and you’ll never end with ideas,
“Talon 5x7”0.5mm thick,!! Heat… Remember, Shepard, Roos, Hex Mag, Black Wings Grip… “:Amazon.com
I’ve probably used at least 50 different brands and types of stuff, from skate board no slip, to some really nice pistol grip materials with some great designs, sky is the limit frankly, my shrink thing on that one light was what I had on hand and knew it wouldn’t cause HEAT issues, that you always have to keep in mind. I’ve been doing this to fix up some really ugly lights but they looked cool just had bad ano or something so use this sort of stuff to fix it up… have fun,
Edit: Started doing lights with these types of materials after attempting stuff like powder coating, stripping etc. and believe me this is the way to go, cash wise and hassle free for the most part.
As soon as Hank releases it… which should be pretty soon. He’s testing a release candidate now.
If I come down with a bad case of hit-by-a-bus syndrome, the code is still open and published under a fairly robust open-source license. Not unlike how Tom got busy and I was able to fill in. Fortunately though, he didn’t get hit by a bus; I’m told he is fine but preoccupied with other parts of life. I hope things will settle down soon so he can come back. Unless he’s having a really good time, I mean. I wouldn’t want to cut that short.
I’d have to find a volunteer to do the nut-roasting test.
Can’t do that one myself.
Double-click from off (or from a non-turbo level) goes to turbo.
Double-click in turbo goes to the previously-memorized ramp level.
A single click still turns it off.
To set the memorized level, simply ramp to whatever brightness you want. It also sets memory when turning off, so you can double-click to turbo, then single-click off, and memory is set to the highest level.
Memory is only used for the ramp level, not for the mode. So, if you turn the light off in beacon mode, memory won’t return you to beacon mode.
Basically, during normal use this means:
Ramp up to whatever level you need for walking the dog.
If you hear a noise, double-click to go to turbo and see what happened.
Afterward, double-click to go back to the dog-walking level.
It takes a soldering iron, tweezers, and a toothpick to get the driver out… and some flashing tools. Click the Link in my signature for more information on that last part.
Or, to buy one, just wait a bit and both Intl-Outdoor and Mtn Electronics should have it.
Ha Ha Ha, TK to funny, seriously suggest for folks to just be patient and wait a bit, then no tooth pics, tweezers or toasty nuts, no hay problema, this upgrade to this UI was at light speed beamed straight to BLF via 16H03,
Thus has got to be one of the best UI’s I have ever seen! Nice work TK. This light has made its way to the top of my must have list. Thanks team Emisar.
Life is like a box of chocolates. It gets really messy if you put it in your pocket with a D4 on turbo.
Runtimes, Forrest! Runtimes!
Really though, I love watching LotR: The Two Towers. Because at the end when there’s a scene with the Ents charging toward the tower of Isengard for a battle, it’s fun to shout out “Run, forest, run!”
It’s a long movie, but some things are worth waiting for.
Sorry to make you all wait an extra week for the D4. I hope it’ll be worth the wait.
