TK's Emisar D4 review
Yeah, without pressure holding the MCPCB against its heat sink shelf, it’ll cook itself pretty quickly. That’s normal. It shouldn’t be operated at high current with the heat sink nerfed.
(this also applies to wrapping the pill to make the surface feel less hot, though that has less immediate results)
D4’s MCPCB is 2mm thick, all other MCPCBs are 1.6mm, it is highly unadvisable to use a thinner MCPCB which will create issues with thermal transfer between the head and the MCPCB as the Bezel is holding down the MCPCB by pressing down on the optic.
Neither should the flashlight be used without the bezel and optics in place, doing otherwise will overheat the LEDs.
The D4 will produce tremendous heat on turbo mode, and heat up very fast (10~20 seconds for the thermal protection to kick in depends on the cell), please make sure the bezel always be tightly enough on D4 although it’s checked very well before leaving the warehouse.
Hi Hank,
do you know when the D4 will be available at intl-outdoor ?
Hank, why did you make this MCPCB thicker?
Yes, it’s up now,
http://intl-outdoor.com/emisar-d4-high-power-led-flashlight-p-921.html
The price has been increased once again… :weary:
EDIT : ordered anyway, I’ve waited for such a compact e-switch flashlight too long… and with that FW I could not pass !
Ordered!!! Muahahahahaha!!! :smiling_imp:
Ordered.
Now the wait…
My bank has downtime, doesn’t accept card transactions now :rage:
Guys / gals, which one did you pick?
Black 219C
Grey 219C
Green 219C
Green 219C + 18350
Same. Can’t wait!
Ordered grey 219C + 18350 + tracking…… :person_facepalming:
I hope spent less….but is ordered now … :smiley:
I’m into green 219C + 18350 too. We’ll see if the stock lasts long enough for me….
Grey 219C
is there any other benefit for XPL version other than slightly higher lumens, does it throw further?
Double die size than 219C, so probably shorter throw?
Green 219C + 18350 ordered, 15-20 days until I get it :slight_smile:
lol i shouldn’t be ordering more lights now…but hell i wont be able to sleep.
219C is nicer anyway Green 219C ordered :email: :smiley:
Would love to see 26650 D4 with more emitter.
You mean D7? It’s on the way :slight_smile:
Got XPL in green with 18350. Wanted to get the 219C also but got to save money :frowning:
