Thank for the review. Just ordered the SC01 in silver/white yesterday. Yea I guess the difference in throw of the MT02 vs SC01 can be explained by the XHP35 HD vs XHP35 HI
Thanks for your good review. In part it has helped me to buy it. I love this flashlight, I hope it arrives soon.
I think you made a small mistake in the review. You’ve put some things into “cons” by mistake, I think.
Things like:
“Tail-stand? And it is
Mechanical lock-out but needs few turns, Electronic lockout is available.”
I even think this:
“Got hot on turbo but still manageable, but in colder environment the turbo could be well maintained.”
Is a pro, because a flashlight with this size and this power is normal to be hot in turbo, and if in fact that heat is not exaggerated, it seems good news.
Agreed i’ll fixed up right away. it probably got mixed up in the editing form
I have to redo the Burn test and i also add 2 more minutes to the test, as i just realized my battery was not fully charged, the behavior almost similar slightly hotter though.
Thanks again for the review, can I ask you a favor? Could you show a photo whit the Haikelite SC01 next to the Ultrafire C8 and the Convoy S2 +? To get a better idea of the size, thank you in advance, greetings.
I just received my SC01, and a bit disappointed in the turbo lumens and throw.
I measured the modes as follows:
Mode Spec lumens Measured tail amps
low-low 20 48 0.10A
low 200 255 0.46A
med 500 615 1.28A
hi 1,000 1,074 2.69A
turbo 2,000 1,639 5.65A
Turbo throw: 60 kcd (measured at 5m), 490 meters
This light is a 40.1 mm diameter head, and reflector I.D. of 31.0 mm. An Eagle Eye or BLF X6 has an I.D. of 29.0 mm, so it's a little bigger which is good, but puts it in about the same class.
I would say the lumens in turbo is about expected, compared to hi mode - the higher the amps, the lower the efficiency of amps to lumens. Also I think the 60 kcd is expected for a reflector of this size,and these amps drawn from a single cell with a XPH35 HI.
To get 92 kcd from mine, the lumens would have to be about 2,400, 50% better than what I'm getting. The optics in mine looks good: nice AR lens, reflector looks perfect, LED is aligned well and seems reflowed well. I can't see anything wrong, but who knows...
For the low turbo lumens issue, going from hi to turbo and double the lumens, you have to more than double the drawn amps by quite a bit. 2.7A to 5.7A is not enough to double the lumens. It would need over 6A easy, maybe ~6.5A would get you close. You can see the delta from med to hi in amps vs. lumens, and at higher amps, the ratio of amps to lumens has to be even higher.
i am not sure how comparable your result to mine, but my Luxmeter could read higher.
I have no way of measuring Lumens other than using relative ceiling bounce but then again the result is not comparable to others.
This are the relative lumens output on some of my lights. it is below MT01 and MT02 and above BLF A6 but i have no idea how much Lumens my BLF A6 made. But on thing a agree on is that SC01 doesnt output 2000Lumens.
This I guess makes me feel a little better (i think), because just from purely looking at the difference when I would go from High to Turbo, it was very subtle, so it made me doubt that it was actually 2k lumens (dont have a light meter yet). When compared to the KDlitker, output seems to be almost identical. Again, this is me just looking at the output using my eyes so very subjective.
I recently bought an SC01. As has been described by one or two others, I encountered a switch/driver issue which requires multiple button presses for the light to turn on. Within a few days of purchase, I emailed Haikelite, and they ignored my email. I sent a follow up, which they eventually responded to but did not offer any remedy (they did ask if I would be technically able to replace the driver, but did not actually offer to send me one). Follow up emails were also not responded to. I cannot think of any reason why I would buy a Haikelite product in the future, since the company does not seem interested in resolving customer issues and is horrible about responding to email.
Ohhh - had to widen my screen. Pics were vertically stacked, not next to each other. Once widened, makes a lot more sense
Looks like CW vs NW and the smaller reflector D1 has a tighter beam because of the XPH HI.
Mine only throws a fraction of yours, 60 kcd vs. 92 kcd, so yours is really tweaked, or mine is pathetic, both factory stock. These things do seem to happen though from HL - I've seen it with the MT07 and MT03's.
Even 60 kcd vs. 43 kcd, the SC01 should easily beat it, but doesn't seem that way in the pics, the last shot specially. It's like the lights are reversed or, the D1 does 80 kcd and the SC01 does 40-50 kcd -- the pictures don't make sense against the specs.
Wonder if coaox tested kcd, or maybe modded up his D1.
I think that is a beams shot of the D1s, which isn’t released yet, but I believe freeme has a sample. It’s a C8 sized thrower, not a pocket thrower like the regular D1.
