NarsilM - configurable e-switch firmware for Multi channels, v1.3
Darn, quoting your post mangles it up badly.... No time to fully respond right now but you got some very good points there, excellent feedback!!
Looks like might be 2 bugs and/or some unintended behavior. Other things are behavior as intended/designed.
Agree - the moon mode custom setting has some quirks to it, and how it's related to ramping. I was always well aware of it, just didn't get into working/thinking out something better.
But, really really like some of your suggestions - dang, might have to work on those real quick, but having no time right now.... Really like your suggestions on the 2X+ click changes... Not familiar with the Zebra UI - would be an advantage to have some consistency there though with it.
In this case, The inducator led works still?
and
LVP is set by R1/R2?
If the driver is wired to put the indicator LEDs behind the Zener/LDO, or the indicator LEDs otherwise have the right voltage going to them, I’d expect it to still work on a 2S/3S/4S build. They might need somewhat different resistor values though, in either case, to compensate for higher voltage.
About a Cheat Sheet for Narsil M,
lock here New BLF GT Narsil M Cheat Sheet for v1.2 NEW VERSION
Maybe somebody find it usefull.
I got a weird problem with NarsilM when the FET is limited to 90%
the ramping table is edited to be 230 max and also the mode sets
is there another aproach like reducing the ramp size or so?
but when the stepdown occurs it goes to 100% in first step down
same with ramping like 0.1, 1, 5%,10, 20…., 80, 90, 100, 90
I found a bug in Triple channel buil
the Indicator LED is not working, djozz reported it and I can confirm it
must be maybe the pinout settings are not right or some line of code wrong
channel.h forFET+1 build
channel.h for triple build
I'm pretty sure I got triple channel NarsilM 1.0 working fine with a Ind. LED. I have it installed now, from June 1st or so, in an OTR M3. It's got the delayed dbl-click, all the features of NarsilM 1.0 and uses TA's triple with 3 7135's as the bank:
Link to NarsilM v1.0 folder with the special Setups-OTR M3.h header file: https://drive.google.com/open?id=0B1IxYZuk4DjcQWhOOGhTMExCNjg
You cant use external R1/R2 if you have the Indicator LED enabled. Works fine for me.
Hhmm - is the stepdown in mode sets? Is this still a problem? I'm gonna be working on this feature for the BLF GT, at least add the option into NarsilM. Plan on setting a max of like 80-90% for ramping, but still allow the dbl-click turbo to go to 100%.
It looks like you are talking bout mode sets, not ramping. Sounds like you didn't configure it correctly, but not sure. Think I already had a factory set of modes that didn't go to max output and I recall it worked fine.
Even with the setting file you gave me I got the same problem the indicator LED does not light up when it should
I get some light up of it,
but not as it should be,
the blinks which indicate which bank is active, voltage read out and standby does not work
It’s rather impressive seeing all that in such a small host.
If you were so inclined, you could probably sell those for twice as much as the Olight S1 (S10?) it’s cloned from. Not sure that would be enough to make it worth your time, but it sure would be nice if there was a BLF light with the form factor of a S10/S1/S-Mini.
It was a challenge for sure. Sanding down the driver PCB was the most time consuming part. It is amazing though - same basic driver/design in a 37K lumens 16X XHP50 light, and the tiny OTR M3. I carry the M3 in the little pocket inside the regular jeans right hand pocket - no scratches, feels fine, no accidental ON's, don't have to lock it out.
All the pics here on the M3: http://s1054.photobucket.com/user/TomE2012/library/Custom%20Mods/OnTheRoad%20M3
All the pics here on the 16X S88 clone, 37K lumens monster: http://s1054.photobucket.com/user/TomE2012/library/Custom%20Mods/16X%20S88%20clone
Hmm? I haven’t noticed any problems with the indicator led either. But maybe I don’t know how it is actually supposed to work and therefor I’m thinking its working. What can I test to see if mine acts as yours or if it is really working?
I have high hopes for this one. I have it on the way. It’s hard to believe it has all the features for the price! And I’m thinking the space inside the head is going to limit the use of custom driver? Just think, add USB charger to that board Tom made :person_facepalming:
My M3 definitely works, been checking it. If all those things don't work, what does work? Does anything work with the Ind. LED?
I'm thinking maybe you got the default config settings set to disable the Ind. LED function, maybe?
These settings should be as follows:
define DEF_LOCATOR_LED 1 // Locator LED feature (ON when light is OFF) - 1=enabled, 0=disabled
#define DEF_BVLD_LED_ONLY 0 // BVLD (Battery Voltage Level Display) - 1=BVLD shown only w/onboard LED, 0=both primary and onboard LED's
#define DEF_ONBOARD_LED 1 // On Board LED support - 1=enabled, 0=disabled
I have not disabled the indicator LED in setup, I even activated it in the UI settings again
I have downloaded the narsil files from your google drive again
put in the OTR M3 setup
build a hex file and flashed it
the LED blinks when I push the button sometimes,
but it does not blink out voltage ot is active when the light is off
Ok. Mine works with battery voltage so pretty sure mine is working too. I’m using narsilM though…
The first I tryed the indicator did not work but then I read through setup, .c and all the included files to make sure the settings were right. However I do not recall what setting I changed in fact I don’t think I even knew what I did different. Sorry this doesn’t help you much though…
Can you upload your NarsilM folder somewhere?
Are you using r1&2? What pin is the indicator connected too?
I am not using R1 and R2 and its connected to Pin 7
I downloaded NarsilM here
I have uploaded the zip here, containing the original NarsilM files with the OTR M3 setup.h and build hex file
http://www.metronixlaser.de/bilder/flashlight/NarsilMulti.zip (link is external)
The only different file from what I’m using is the m3 setup file. I’m just using the main built in setup file. I didn’t know there was an m3setup file. Sorry, I am unable to flash your .hex file right now. That might be helpful. Idk? If your still having trouble I might be able to do that tomorrow. I’ll keep watching. Hope you get it working. Working through these details can be frustrating !
