i usually open multiple tabs at once and the thread title become truncated. If TheMiller could change the title a little into something like “GT: First prototypes have ARRIVED, a BLF special giga thrower” Instead of “First prototypes have ARRIVED The GT, a BLF special giga thrower”
That first word could give a clue as to which thread we are reading. Sometime i replied to wrong thread
nice to see this crazy thing exists now
this light is sooo useless (for me) and huge, that i want it so much!!
btw, i recommend to compare it with Maxtoch Shooter 2x
i`ve tested about dozen of throwers, no one could outperform it.
guys from fonarevka bought it after my russian review and wrote it performed better than olight 3x javelot
Well I plan on zoom my camera on the castle tower 820m away and compare the sample with the current king of throw TN42 (should be little throwier then the Shooter 2x)
There really is no comparison. I've modded a couple early Shooter 2X's, maybe got about 360 kcd (1200m) - think that's the rating of the dedomed XM-L2 U4 version. At 1.1 Mcd and in sheer size, no comparison.
Damn bro thanks for the beamshots. I was looking at maxtoch shooter xml2 u4 dedome… no step down for 70 minutes at 4.5 amp… do you think sst40 dedome would throw better in this light??
Talking about things happening here is a run time chart with the BLF GT proto Narsil running two amps at the end of ramping.
This particular GT also has spring bypasses on the battery carrier.
The runs were stopped when the low voltage kicked in for the first time.
