@MascaratumB,
Also you may read this post about heating up the S2+ at 2.75A, your hands are the first to worry about, and long after that the led and electronics
That is a very nice building, it looked fifties style in your picture and yes it appears to be from 1954.
Thanks for the test djozz! I’ve already seen the post, but only now I read it carefully!
Eheh, I guess I’ll never have to worry about a Convoy getting hot as much as I got worried when I put a battery in inverted position in my Manker E11 (that has no reverse polarity protection)!
That, ladies and gentlemen, was HOT :disappointed:
Only accidentally would I leave a S2+ ON for a long time, and it wouldn’t be in my hands for sure ! That’s one of the reasons why I like these flashlights, I know I can trust them! And my use of them, of course
About the dome, it has been one of our city ex-libris (just like Amsterdam’s arc of “Homo sapiens non urinat in ventum”)!
It needs some restoration, but it has been hard to make them happen… Still, it is a great building with a very pleasant view from it gardens, towards the city and the sea!
The actions: switch flashlight on and half-press the switch more than 10 times until the flashlight stops giving light, wait for first ‘buzz’ and click flashlight off. Click flashlight on again, after 12 blinks switch flashlight off. Now it should be 100% only.
With the light on tap the switch button repeatedly until it stops flashing.
When the first flickering “buzz” happens tap the switch again. This puts it into config mode. It will start counting. One flash then a pause, two flashes then a pause, three flashes then a pause, etc. all the way up until it counts out 12 flashes. Click the light off during the pause after 12 flashes. When you turn your light back on again it should be in mode group #12 which is simple on-off. Hope that helps. It takes a few tries to get used to doing it but it’s much easier once you get the hang of it.
Edit
Dang it! Jos beat me to it.
Edit Edit
How cool is to belong to a forum where people race to be the first to jump in and help another member? :+1:
Thanks a million. It worked at the first attempt. Although I really don’t know what I did, but got the desired setting, so don’t care. Thank you Jos and I am also really grateful to everyone on this wonderful forum. It indeed is a privilege to be a part of this family. Thanks again.
I tried heatshrink tube today on the clip in another light mod and it worked!
I also used in the S2+ tan and works fine, doesn’t leave the scratches it once did
I just remembered what we talked about before and wanted to share!
Just receive my parcel, the flashlight is gorgeous This is my second Convoy S2+
But what does BATTERY CHECK mode means? It just blinks 3 short times, then again and again - and nothing more.
