I guess the full-quote with the third picture within one hour
Sometimes you need to read the same thing three times before you get it.
I have a question, can i use two RCR123A in this flashlight instead of one 18650? I mean in this discussed tan s2+ version with new firmware?
Short answer, NO. It will kill the led and the driver in an instant.
You can however buy 17mm buck driver and mod the light, but that usually means no biscotti or any other BLF developed firmware.
I have just some of 123 - so it is not the problem Will not use them for sure
[…] I tried using sandpaper to smooth the inside rim of the clip, but that doesn’t help a lot, and bending it wider it’s easy to overshoot the correct size. Ultimately, I don’t think snap-on clips can be used without doing some damage on the short run. My first S2+ I used with the same type of clip, it fit more snugly, but it just took a few more turns to the scratches to start showing.[…]
Regarding the clip:
I had the same scratching issue with the clip on my S2 (non +) but it’s not a big deal since I have no need to remove the clip. I find the clip to be an excellent fit and like it as it is, especially as I pocket carry with a clip, almost exclusively. The Convoy clip works well for me!
I tried heatshrink tube today on the clip in another light mod and it worked!
I also used in the S2+ tan and works fine, doesn’t leave the scratches it once did
I just remembered what we talked about before and wanted to share!
Just receive my parcel, the flashlight is gorgeous This is my second Convoy S2+
But what does BATTERY CHECK mode means? It just blinks 3 short times, then again and again - and nothing more.
The number of flashes indicates battery charge level I believe.
4 flashes = highest charge level (close to or full battery)
3 ”
2 ”
1 flash = lowest charge level (low battery)
I am not sure which actual battery voltage values the number of blinks correspond to but I hope this helps in some way :+1:
I was thinking it will give voltage information as in Nitecore for example. Ok.
BTW i rewrite the programming guide to add more structure to it (IMHO), so you can check it
Image link’s broken
Ugh… once again you guys made me buy another flashlight…
I was walking around with my old S2+ (Blue XM-L2 T6-3B 7135*4) last night and admired how comfortable it felt in my hand. It is such a great EDC light. So now it’s going to have a younger brother - Desert Tan XPL HI U6-3A 7135x8. Can’t wait to get it.
In the third row: shouldn’t the “Enter into the first mode” box read “(if the mode memory is off)”?
For clarity, I would also change the “Enter into next mode” box to read “Enter into saved mode” or similar. The current text almost makes it sound as if the light has Next Mode Memory, which is a different system (and one just about everyone seems to hate).
Can you believe that only today, due to your diagram, I realized that there was a “long tap” option to get back to the lowest mode? Whatta….?! :person_facepalming: :person_facepalming: :person_facepalming:
I don’t believe me! How could I not know that…?
Well, thank you for your effort and for the help on this! :+1:
It’s not really a long tap. You just cut the power for a while and the light shuts off. Then it restarts on the lowest mode just like if you would have fully clicked twice with a pause in between.
Sorry if this was covered earlier, but why is the mode spacing what it is, meaning a huge jump from 35% straight to 100%?
If you have the 8x7135 setup, and the light gets super toasty on 100, then wouldnt it make sense to have a mode that is closer to maybe 60-70 to make the heat more manageable while still giving fairly decent output?
I know there is the 50% MAX mode, but then you cant go higher than this without reprogramming.
Because there’s little visible difference between 35% and 100%. Human perception isn’t a linear curve, if anything it tapers off at the higher numbers like a logarithm.
Thanks for the explanation maukka!! I then realized that that was just a slight longer tap than the quick tap for changing modes!
It works fine, I just didn’t know it could do that :person_facepalming:
Thank you! :+1:
I also questioned this before buying but after using my S2+ for a while I realized that the spacing is very well done and thought out.
