This is disappointing. Seems like it's longer than the MT07 by 2mm, which already is too long. With reducing the head diameter by 20 mm, there's no good reason to keep the reflector and head the same length. Longer reflectors do not increase throw - only width does, and a narrow reflector means a narrower spill, and that's about it.
I could have sworn they used to have it listed shorter than the MT07 by about 10 mm.
I would of thought the hot spot on MT07 should be much brighter since larger reflector (more throw) but from this picture it seems less brighter than MT07S
maybe the person took the shot had the camera on auto exposure? lol
The bigger MT07 is much brighter - what are you looking at? Their hot spots should be about the same - both are rated at 750 meters, so I have no clue what's goin on. The 20 mm taken off of the diameter is somewhat made up for with the SMO reflector vs. OP.
Of course we don't know what the I.D. is of the SMO in the MT07S, so dunno for sure.
I'm ordering a SMO for the MT07 right now - HK quoted me $15.
The person is a nice flashlight enthusiastic fan in china, he is good at outdoor beamshot. MT07S is brighter than MT07 indeed. 07S comes with SMO reflector.
Aren't both lights listed at 750 meters distance on your website? I'm confused... 750 meter means the same throw, and both lights are rated, again, on your website at 5,000 lumens.
So, 750m = 750m, 5,000 lumens = 5,000 lumens. That means they are the same, same in brightness, no matter how you interpret brightness.
Like you said, the MT07s has a narrower spill due to the smaller diameter reflector, so the same number of lumens are being shined on a smaller area. Hence it appears brighter.
Sure, you can kind of, sort of reason it that way, but only the spill area may appear brighter, not the hot spot since they have identical throw #'s, assuming the hot spot is the same diameter. I've often seen deep reflectors produce smaller hot spots though, but with effectively the same throw.
Just ordered an SMO reflector for the MT07 from Haikelite direct - should get a nice bump. I already have an XHP70.2 in it.
