New ReyLight LAN available soon
@Trevi
Could you please make a full review of TiLAN?
I am interested too. Do you have access to some trits and options to put some on as your previous lights?
I already contacted OP, but so far the buying process seems “grey” to me :frowning:
You can paypal to 395090663@qq.com
Just got the new LAN v2.0 in house here now.
I got the bead blasted version, nice and grey.
It is a little longer - 3,5mm than LAN v1.0 and 3,3g heavyer.
The LED, Nichia 291C 4000k, is a little more warmer than the LAN v1.0.
Mine is on its way, I expect it to be held by customs, but hey. 3-4 weeks at least.
Is the battery tube the same diameter as the Pineapple? One thing that bugs me about the Pineapple is that it can’t take my Keeppower 14500 cells. They’re too thick. The battery tube is just wide enough to accept Eneloops, or unprotected 14500’s.
Since I’m not sure if the light has proper low-voltage protection, I’m reluctant to use unprotected 14500 cells in it. So, I’m stuck running it on AA’s, which makes it under-powered by today’s standards.
My nitecore and olight, xtar 14500 , protected, could work well. It does not have low voltage protection.
Hi WalkIntoTheLight…
Just measured, I have old protected Ultrafire 14500 that is 52.2mm long x 14.43mm wide and it fits in - no problem.
The same battery may be squeezed into the Pineapple or the LAN v1.0, but it works fine on the v2.0, so this tube is
a “hair” wider than the two other. These are my numbers.
Hope it helps. Good luck.
On Amazon US now.
LAN 59$ after code: J6PSMOWA
Pineapple 39$ after code: IW3C96K8
Think I have fixed it, active at 2017-9-16 07:00 PDT
Rey, Is LAN v2 used the same driver in pineapple? Any plan for a batch run of copper pinapple or copper LAN?
Yes, same driver. Currently planning on triple.
Ti & 18650?
Yes.
Damn. There goes my wallet…
I’ll be waiting for that one :smiling_imp:
Meanwhile, great work on these lights Rey! :+1:
I’m not sure if I’ll get one, yet, but will post here if I decide myself for one !!
Looking forward to your efforts!
Any updates on these various versions release dates???
The colorful one? or V3?
