you are right about the small output difference. and i also notice Olight X7R or most Olight CW are slightly green tint. M3XS-UT has the worse greenish tint imo. And thanks to your input I requested in time to change to Neutral White - XP-L HI V2 3A, 5000K….phew that was close! :innocent:
No need to cut threads as the area it eventually resides on is unthreaded.
I used a rotary tool with a sanding drum and slowly removed material until it just fit over the threaded sections.
It doesn’t leave a whole lot of the ring after enlarging so if you have to bias the cut in any direction I’d take a little more off on the side opposite the clip.
Depending on the thickness of the paperclip the clip may still rotate. If you want it to remain stationary you could flatten the paper clip with a hammer to get it down to size so the tailcap grabs it tight.
IMO nothing beats a screw-on clip, I’m looking at that option from all directions. Will spend too much buying tap, screws, deep-carry clip with holes…… flashoholism.
Oh, it gets hot but steps down within 30 seconds. There are a number of posts with members’ own accounts of D4 ‘behaviour’. I put o-rings on mine for the heat and a grip. Sorry to hear about you first D4… hope you get another.
This morning, I crimped some gold, flat speaker pins onto a short length of 14 gauge Monster Cable and terminated the other end with dual banana plugs. Plugged them in to my old Craftsman 82082 DMM and the light tested at 11.9A. I see the light… and now the numbers too! :+1:
Version B from my MH12. As you can tell, it’s a little too thick for the groove but it works well enough for me so I’ve been using it for the past week. Other versions might fit into the groove. There’s not a sharp edge on this clip and it’s pretty heavy duty. Been on my work MH12 for about a year. Really deep carry on the D4. It sits about a 1/16 of an inch lower than the battery cap.
Hank, not quite the same, but would a lanyard on a pocket clip work? That way you’d have both options. That’s what I intend to try, but the pocket clip is the most important option. My lanyard will be a finger lanyard on a light this small (I hope). I’ll need to play with it to see what I can come up with.
Sorry about the photobucket pix. I hope they go bankrupt (and they are in danger of that, whoopppee!) .
I don’t want to wrap the flashlight in insulating nylon cord to attach a lanyard.
If I can get a ring onto it somehow, that’d work fine, I use the little spring “lobster claw” clips a lot attached by split rings to flashlights that have the little hole drilled (or I drill the hole … hmmm ….)
The Solarforce belt clips all have little openings suitable to attach a split ring. Usually I attach glow-in-the-dark keyfobs that way (hat tip to Andygold who made them for a while).
That Nitecore clip looks close, but the arms are a little too wide and the place where the arms meet has an extra tongue thing to catch fabric on. It might be about right after some minor adjustments.
Do the fingers stick out far enough to get in the way?
I’d guess that’s a (poor) attempt to solve the problem you’d get without that extra tongue thing — the right angle connection between the legs and body parts snags fabric in my experience with Convoy’s clips.
I have one clip that makes that transition a smooth curve that feeds the fabric or belt edge into the narrower part of the gap smoothly. It came on an Orcatorch T11:
Here’s another look:
It’s solved that cloth-catching problem nicely. I wish they had several sizes and sold them seperately but, no.
That tongue-free design is the same as I’ve seen on recent Olight clips (S-Mini). Their older ones have been pretty nice too though. I’m hoping one of these might fit:
(not sure if image matches actual product; they use the same image for several different clips)
