TK's Emisar D4 review
Thank you, I will buy one.
I know that fasttech has some holsters:
https://www.fasttech.com/category/0/search/p/0?&keywords=Holster
Maybe this:
https://www.fasttech.com/products/0/10005190/1411401-ultrafire-nylon-flashlight-holster-black
I’m not sure which is the best fit.
Hi gregor:
The ganzo holster also available in fasttech (not aff.) at 1,87 USD
Ganzo holster in gearbest (not aff.) at 1,23 USD
The Ultrafire of fasttech that shows at 2,88 USD is interesing, some one Can confirm that fits fine?
I nobody else have this FT ultrafire holster, I can buy it and report my findings.
How quickly is FT with delivery. I last ordered from them long time ago and I think parcel arrived in around 1 month, not very quickly.
Fits snug in a magazine pouch. Will probably fit the D1 as well.
Emisar D4 Clip
I have been looking for a suitable clip for the D4 also. Today i tried using a clip from a Convoy S2+, it is almost a perfect fit except it is a little long.
I also used heat shrink tubing around the ring area of the clip to protect the body from scratches. Tubing dimensions are 4mm in diameter and 24mm length. Used a small torch.
Very easy mod to do and should be ok for now until i find a more suitable clip.
Here are the links to pics showing what it looks like.
  1. To add GITD.
  2. (Maybe later) To replace the emitters.
Is that a standard 18350 body? And a trit?
Just ordered a Gray D4
It’s heavily modded by CRX.
I got around to installing an old Solarforce clip on my green D4 tonight. As I read about here, I needed to open up the inside diameter a little and install a conductive spacer inside the tailcap.
Hello, jfg! Welcome to BLF! :slight_smile:
Does your name have anything to do with coffee?
My SolarForce L2 clip has been working pretty well, but I should probably find something a little better than a paperclip to use as the spacer. It seems like the paperclip has reduced maximum output a bit.
The clip itself could stand to be a bit shorter, since it routes fabric directly into the edge of the clip groove. It’s not bad though, and I appreciate the wide opening on both sides of the contact point. It’s also nice that I can add/remove the clip without scratching anything.
Yeah, sorry, there is no strobe or bike mode on the D4.
I enjoy some blinkies at times, especially party strobes, but those weren’t part of the D4 design. If you ever get the chance though, it’s fun to play with water under a motion-freezing party strobe.
Ok thanks
Hi Folks,
is there any discount coupon/code for Intl-Outdoor?
Thanks
I used a piece of solid copper wire. I had flatten it with a hammer to allow the tailcap to tighten down enough to keep the clip from rotating around.
Its not ideal. I’d prefer a clip attached with screws, but this solarforce clip is alot more secure than a snap on clip.
Question for Hank Wang — can you sell extra tailcaps?
I want to try some drilling and fiddling to attach a belt clip and lanyard/split ring attachment point.
Finding a copper ring/washer the right size to fit in the tailcap to use the Solarforce belt clips would also be good.
The main problem I have with this flashlight is it’s easy to drop.
And the very last thing I’d want to happen is to drop it while it’s heating up and have it land in an unreachable place and start a fire.
No, Hank doesn’t do inflated retail prices in order to have periodic sales. The price is set at fair value instead. However, compared to the competition, the D4 is 59% off.
Got a modified 47’s PK Paladin clip to work
That’s a sweet clip. Did it need to be reamed or anything to fit?
It looks like the clip’s ring had to be cut and the arms bent out a bit.
