Second unit ordered
Thanks
Second unit ordered
Thanks
3rd ordered, colleage promised to order my 4th one on the code.
Yeah, something goes wrongā¦ā¦
Only the Q8, I bought 8x 30Q too, but it shipped in the same dayā¦ā¦
I dont tried to reorder because the refund dont came yet :confounded:
This is the only thing I can see in photobosta
I will not pay $ 400 for a photobosta account, there are free places to upload photos
Yes, youāre not the only person who wonāt.
https://www.google.com/search?q=photobucket+embed+fix
Fix for the Photobucket screw-you change is available for Firefox too
Sam3gX:My switch LED went out 3-4 days ago and havenāt been working since. It was flickering before it went out completely :cry:
Argh, will add you to list.
Please can you make pics of switch assembly?Of somebody sees the flicker indicating it might be a switch led issue please shoot a video of it, that is helpful too.
Did you forget to add me to the list?
1726 preorders right now. Thatās almost 99% of the interest list! :+1:
I donāt know how many hours (if any) are left before the GB code expiration.
hey all. i got my Q8 today. thank you, its look and feal good, but i got issue with the driver position. can see it in the picture.
i hope somthing can be done to fix it.
btw, i did not put batteryes inside yet.
You can unscrew the driver and use a 3mm drill to open up the holes for the screws to be the same size as the screws so they donāt thread into the driver, but only in the flashlight body, that will make it sit more level.
The battery marks are normal, every light is tested before it goes out of the factory.
EDIT to put link with picture : Q8 modding - #373 by Etex
(wouldnāt fear warranty issue, no one can see ;-))
T-boon:hey all. i got my Q8 today. thank you, its look and feal good, but i got issue with the driver position. can see it in the picture.
i hope somthing can be done to fix it.You can unscrew the driver and use a 3mm drill to open up the holes for the screws to be the same size as the screws so they donāt thread into the driver, but only in the flashlight body, that will make it sit more level.
i could try it but fear of warranty issue. :innocent:
Yes, and you might see a little bump in output when done
This is very sloppy assembled.
Which warranty?
T-boon:i could try it but fear of warranty issue. :innocent:
Which warranty?
not sure actualy, i assume there is some warranty if the light dosnt work.
The code isnāt lasting long is it being extended? We had the BLF A6 code lasted for like 6 months.
I want to order mine when itās ready to ship.
Go for it. At least your driver screws have good heads, not stripped. You seem to have the standard problem, screws threaded into too-tight holes in driver PCB, so driver doesnāt sit flat, so only small contact around the screws, nowhere else.
The Miller has said not. Order tonight if you want one at $40, with support from BLF. Future price for production units indeterminate, maybe codes available, maybe similar price, who knows ? Next batch should have niggling issues fixed, The Miller has said (new switch LED board, better screws, more attention to proper assembly).
Looking forward to mine.
I'm tapped out on my 10 pre-order limit. Any other option accept to buy from Elfeland? Can't find any other discount codes floating around, but if M4D M4X had one, it would probably be thru BG anyway where my limit was hit.
Iām tapped out on my 10 pre-order limit. Any other option accept to buy from Elfeland? Canāt find any other discount codes floating around, but if M4D M4X had one, it would probably be thru BG anyway where my limit was hit.
If you are really stuck I have one spare code. Just one.
1st of 2 arrived today. Looks fine, will dissect it in a few days
Mike
Tom E:I'm tapped out on my 10 pre-order limit. Any other option accept to buy from Elfeland? Can't find any other discount codes floating around, but if M4D M4X had one, it would probably be thru BG anyway where my limit was hit.
The code won't matter - I can't even submit the order, or add it to the cart because of the limit.
Guess I could create another account, I suppose, under my wife's or daughter's name. I got a code to use (I know a guy...)
