If you want to see what some people do with UV lights look at this site Nature’s Rainbows . There is a post there on the Convoy S2+ with the Nichia emitter. Honestly I think this is the light all budget UV light should be judged against. For $20 I think you should just get the Convoy and forget the others. Thanks for the review though, you never know what you will find.
UV doesn’t pass through PMMA too well, or hardly at all.
I guess the little UV Jetbeam uses the proper material for their TIR, but unfortunately it has no filter (you know, the ‘black’ glass lens).
You have a point.
On the other hand, and not meant to offend you: a light that emits more visible light than UV light is pretty useless IMHO. Read the reviews on this site, or on the site https://www.naturesrainbows.com/ . The Convoy I got came with a ZWB2 (black) filter, but you can buy them separately. It is a world of difference. This filter blocks the visible light, so we don’t have to ask ourselfs constantly, was that fluorescence or wasn’t it.
Nope, my UV zoomies have a glass lens swapped in.
Polycarbonate is hopelsss at 365nm (Carclo)
PMMA works, but blocks quite some 365nm light too (Ledil)
The OP describes a led that sounds like 365nm, or close, so perhaps a PMMA TIR is used.
i can;t see the UV, so how would i know what the ratio is?
i do know the light gets warmish in a minute or so, so i assume there is a lot power going somewhere, i hope it;s to the UV, not just the visible part, or the heat itself…
Most 365nm leds emit some white/yellowish/greenish light, that is apparently inherent to the design principle of these leds (385nm and 400nm leds do not have this). Nichia 365nm leds are better in that aspect, the amount of visible light they emit is minimal (but not absent). Compared to the invisible UV-light, the visible light is only a small part of the output, but it can blur any fluorescence that you want to see.
To get an idea of the ratio, point the light at a piece of white photocopier paper, the blue fluorescence (that is a measure of the UV that it comes from) hugely over-shines the visible light from the led itself.
