That is to be expected from Banggood page. Mine still shows “not found” there. This is normal behaviour for Banggood. IME. Usually nothing ever shows there until I have actually received the item.
You have to take the tracking number from BG and paste it into e.g. E404 to get results.
I was looking for them as well and settled with flat tops from GearBest’s “China” warehouse. Those are available to ship for a decent deal. I couldn’t find button tops at any reasonable price.
Banggood got button top ones and now idk where else to order them…. I know with a small mod by remove those plastic rings can let the flashlight take flat top batteries. But I like to keep my stuff as they are from factory if nothing is broken…
How difficult would it be for a noob like me to replace the driver, if I practice some soldering first? I’d like to get started on some electronics projects, and this looks really tempting. If it is too advanced, I would be happy to pay someone to do it.
Would these drivers be available loaded with the caps, resistors and chips? I’d be able to solder the wires, but have never worked with such small componnents.
Lexel could probably solder some led wires to the driver for you, then you’d route the wires through the center hole and solder the ends to the led board. There is easy access as seen in this picture.
I know the wiring is different, but it should still be 6 solder joints minimum. It would be easy for a novice, but if you’ve never done it before, practice a little first.
Thanks, that’s about what I was expecting. I usually pick up new skills pretty easily, but like PBWilson I wouldn’t dare to try and add any components to as circuit (yet).
Boss is not in office, i can't get hold of him. I have not seen the actual updated unit yet, but i was told that all units sold from Oct 9 onward would be from 2nd batch with new LED wiring.
The way Lexel does it is called reflowing. It’s like making a pizza. Lol
You apply a little solder paste to each pad, then place each component into position. Then you put it in an oven for a very specific time/temperature cycle. Then boom, they are all soldered.
There are reflow videos on YouTube. You should check out a couple that shows the componentS moving into position. It’s really neat.
Thanks. That’s interesting. You mentioned there would be a minor output bump of like 200 lumens or so I believe, and there would be less heat at the same time for the second batch. So who knows there is a major driver re-design with a boost driver. Honestly, if there is such a difference, testing the new batch and comparing to the first one would be really nice as well. :partying_face:
