[Finished] 5. Batch "TA" Bistro HD OTSM/Narsil drivers, 15-47.5mm size fit H03, MF01, MT03, Q8 1S or 2S, Clicky or E-switch
ok thanks for explaining.
So I’m stil up for
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 8AMC
Now that I have read through things a bit more, I am liking these even more.
When you can get to them,
(2) 30mm 2S NarsilM LDO 65°C, SD=6V, PO=(NO), lighted side switch, LED wires, no spring
shipped w/tracking please.
Not sure on the wire length, as I dont have the hosts (Convoy L6) in hand yet. Seems common enough I trust your judgment on that, just let me know.
Thanks,
Jim
I can do this in this batch, but I have to wait to stock up parts and 30mm boards
Sounds good. I am in no rush. Got several others in the works right now to play with.
Lexel, on the 2S boards for the L6, are you still using the 4700k resistor for the switch light?
4.7K ?
I use 20K
20K~30K are fine?
Yeah, I use 15k to 30k.
I was just gonna suggest Lexel increase the resistor value for these 30mm 2S L6 drivers since everyone usually uses 2 leds.
I had another question. Is this accurate?
Could you sacrifice temp protection in order to get LVP and the indicator function?
temp does not need a pin, the other 2 does
The 4.7k is the minimum resistor, other values are possible, of course rewire the switch board for diodes in series increases the efficiency
Temp doesn’t need a pin? Is that only in NarsilM?
I remember on the older Narsil that I had to choose between temp or lvp.
I chose lvp and no temp. I’m a little confused about this.
The Convoy L6 switch LEDs are parallel. It would be a major undertaking (cutting traces and adding wires) to make it series.
This was the choose between v1.2 and 1.3, 1.3 does not support LVP in 2S, but got a lot of functions like temp sensor readout and use
Just a heads up, Lexel. It looks like the 2nd generation of Astrolux MF01 have a new wiring pattern on the mcpcb (along with a new driver design). We will have to see if the TA driver can be compatible with it.
you would have to modify the MCPCB
Narsil can be set up for modes with different mode groups
21mm fits my H03
OK today 200 AMCs got delivered, so we can start to build drivers
6S LEDs? and holds 4 batteries? Not without ledboard modifications. Not a chance.
hello, am i able to order a 30mm driver for an Convoy L6?
I got 30mm for L6 in stock
just I need the settings you prefer and I can flash and test it the same day
hmmm mybe im in a lil over my head. i know i would like the bistro ui but alot of the other info in the first post im struggling to understand.
I would like to get max power out of my L6, any suggestions?
Nasil firmware have the ramping brightness which is better than bistro UI.
