My newest UT01 in NW came yesterday and is having the same issues as have been described above with the whacko non re starting after battery removal.
Also this one would not go into programming like the old one by double clicking and selecting from strobe group.
The non drop down turbo was not in the strobe group.
However after using a Eneloop and giorgoskok’s method described here (in the OP from a thread back in Dec2016 Review : Utorch UT01 Flashlight (XP-L V6 / AA & 14500 / e-switch) ) to get into programming, now the flashlight seems to behave normally and the programming option is now added to the strobe group.
Here is his method;
Light has programmable output levels for every mode . Here is a how-to :
1) Turn on the flashlight , navigate on the highest mode , and turn off the light
2) Press the button until it blinks two times (it will turn on in highest mode , and flash 2 times after 7-8 seconds)
3) After it blinks twice , release the switch and double click again (It will enter strobe , beacon etc and a constant current output level & regular modes )
4) Now navigate with single (short) click to the lowest mode
5) It will ramp through 3 different output levels . Single click confirms selected output level of mode and goes to the next one
6) Do the same for all the modes , and when you are in strobe turn off the light with a “long” click .
Now the light will accept battery changes in both 4.2 and 1.2 volt batteries.
HTH and thanks giorgoskok!
Later,
Keith
P.S. I also now just unthread the head to change batteries, seems easier threading than the small tailcap.
Hmm. I first used the light with an eneloop. I think I noticed this problem after trying 14500 cells, though now I have it with Eneloops as well.
After looking more closely, it seems like something bit in to the wrapping at the top of the 14500 I tried. I’m pretty sure that was is the three leads poking through the PCB. Mine look to be quite a bit (~1mm or so) longer than what I’ve seen in photos of other people’s lights. It looked like one of them was bent towards the middle one and may be making contact. I tried straightening it out and trimming the leads. Unfortunately, the problem persists.
Joeinchina, it is interesting that the problem goes away if you run the light without the casing. That makes me think that your problem, and perhaps mine, has a mechanical aspect, like a short or open circuit contact when under pressure. Either way, my operating hypothesis is that whatever it is, it leaves either the MCU in some sort of “wedged” state, or the main mosfet and/or its driving circuitry isn’t able to fire more than once.
I’m thinking on using this driver in another host. Is the switch mainly to blame for many of the troubles or are there problems with the driver as well? I’m tryinf to decide if it is generally reliable enough to repurpose. Any out there had a reliable UT01 for a good amount of time?
So this light just regain popoularity recentlt, i see
For 10$, im sure this light is one of the best bang for buck
I am having one, for half a yeah i guess, is there any changes in new batch, if not, i am considering getting another one
I wonder if perhaps they’re more ‘14500’ sensitive than we think.
I’ve been using my two at every opportunity since they arrived, using only Energizer Ultimate lithium primaries, and so far I can’t even coax an error from either. I’ve tried loosening the tail cap (even when lit), cycling modes rapidly, and using them for long periods as candles. So far, not a flicker of misbehaviour. I’m amazed at the runtimes; while I haven’t been keeping track or doing any formal runtime tests and using all modes indiscriminately, these things act like they’re never going to die!
Alternately, since these are being offered at what feels like a ‘clear out’ price, I wonder if there might be a high incidence of problems and Utorch simply wants to empty the shelves. I’m reminded of the Thrunite Neutron 2-AA of a couple of years back. IF you got a good one, you had a wonderfully efficient and truly outstanding flashlight. The trouble was, there was a high incidence of problems, so the model was dropped in favour of the not-quite-so-efficient Archer.
I have two more inbound that I intended for gifts. I’ll put them through their paces as well when they arrive (I don’t want to gift ‘problems’), but so far I’m really impressed. At $10 apiece, even if I get two good ones out of the four, I’ll still feel I got a bargain.
I recently ordered another one for $9.99 and i hope it’ll be good too, but after reading the recent posts here, i think i can expect some trouble…
Juts to be sure, aren’t the 14500 problems you guys mention due to the limited length of the battery compartment?
I modded the tailcap of mine to gain space for protected button top 14500s, otherwise i couldn’t get the tailcap to screw on all the way.
But the problems i just read sound like they have a different cause…
I ordered one today for $10, OK $12 somethiing with priority line to get it faster and tracking. Hope the SW is good. I will certainly put a few switches in my cart for the next electronic order.
I don’t believe that to be the case for me because I am using unprotected, flat top 14500 IMR (efest purple). So they are as short as possible, and at no point do I get the feeling there is excessive pressure.
I dont use protected cells, but that would really be the only way for me to confirm.
As near as I can tell, my problem seems to be something in the driver
I forgot I uploaded a video on the programming aspect of these lights:
The lowest output is about 2 Lumens with either chemistry. As near as I can tell the only difference is in the brightest turbo setting. Where 14500 gains the full ~750 OTF. On an eneloop the brightest turbo is around 375 OTF.
IIRC these lights have a low voltage protection… so you can’t run dead alkalines (or any battery for that matter) completely dead. Someone please correct me though.
The light does have lvp but it’s not voltage based alone as it will run fine from 2.5v-3.2v without problem as long as the battery can provide the power. If the voltage sags too much and fails to deliver the expected current the driver shuts off.
Re problems: reviewing back through the thread does not confirm wether or not the problems are switch related. The problems are all related to using the switch and in some cases changing the switch solved the problems. But there has not been enough reports to indicate what is the status after changing the switch to confirm for certain that it is the switch.
One theory I have is that the problem may be related to how the driver handles reading denouncing of the switch. Different switches have different response images even with the same switch model so if the driver is not calibrated to a wide enough variance there may be problems even if the switch isn’t technically faulty. If this is the case, changing the switch may help or it may not
