Well I this afternoon cleaned up properly & modded both my Q8”s.
First I sanded the top of the battery tube where it makes contact with the ground ring.
Then I cleaned & very lightly sanded both the positive & negative contact rings, after ensuring the board was sat flat, & where the screw holes in the tail board contact the battery tube.
I then tinned the screw holes in the tail board where they contact the battery tube.
Lastly I swapped the tail board screws for brass ones.
All this gave me an increase of about 400 lumens from my previous stock reading taking it up to 5860 on start up on freshly charged 30Q BT”s at 4.20v.
I then removed the tail board again, ripped out the small thin inner springs (just pulled them out quite easily) & bypassed the springs with 20awg silicon wire soldered to the board by scraping some of the red coating off halfway between the spring & screw hole.
This resulted in a start up reading of 7650 lumens in my light tube & 6950 at 30 seconds again on 30Q BT”s at 4.20v after 30 seconds.
I am extremely happy with the gains for what are simple, cheap & straightforward mods/cleaning up :+1:
Yes it is
I had previously only seen a big jump like this when I “solder blobbed” the S70 (not that I have done much “modding” previously).
Does this show that the ground path on the Q8 is not very good as stock & in particular the springs are giving a lot of resistance ?
Or does it show that the Q8 is easily modd”able as was one of the design parameters ?
Either way for the extremely low cost of a few cms of silicon wire & 4 brass screws & maybe half an hours cleaning/sanding & soldering the results in terms of lumens gains is fantastic :+1:
Sort of a combination of those things Ian, the springs are typically gold plated steel for mechanical function, so the bypass is always a gain and in the case of 4 cells and 4 emitters it turns into a large gain. Not that factory lights are bad for having springs made of steel but in this case the ease of modification makes it a big plus. Welcome to the world of improved EDC!
Hi Dale, the Q8 is a bit big for me to personally class it as an EDC light
Then again as I am on the list for a GT, then in comparison to that monster, I suppose that you could call the Q8 an EDC light
In the fall and winter with a jacket or coat, the Q8 is handy enough. When it’s hot out and we’re wearing T-shirt and shorts, well, the Q8 is a bit more difficult to have tagging along. We had a brief taste of cooler fall weather but are back up in the mid 80’s as usual. So it’s T-Shirt and shorts with sandals weather in November. Nothing new there. Need to figure out a good lanyard mount for the tail cap……
Mid 80”s is your usual fall weather
We don”t normally get mid 80”s in the height of summer here in the UK, maybe 1 or 2 days a year are that temperature & not every year.
It is Autumn here now (fall ?) & the last 6 or 7 nights we have had frosts (temp below 32f) & maybe 50f in the day.
Only good thing is that at the moment it is dark from about 5pm to 7am so 14 hours of dark.
At the height of winter it will be dark from about 3pm to 8am but temps will be down to low 20”s F at night (maybe 10-15F) & daytime will struggle to get above 32F
We’re much more likely to be playing with the kids toys outside on Christmas day in shorts and shirt sleeves than to have snow, very seldom does it get snowy here… an ice storm once in a while in late Jan or early Feb, but it can be icy one day and 90 the next, no joke!
The plastic rings for reverse polarity protection are a good idea, something I suggested a long time ago (at least the inner ring), but the brass ring on the driver is too narrow in diameter. Samsung 30Q “button tops” from Bangood for example only overlap this ring at the outermost edge by maybe a mm, or perhaps 1.5. So it might not work for these. The inner piece could work against a reversed cell, but the outer ring might, I think, just prevent the cells from making contact in normal conditions, i.e. a fail.
There does seem to be a disconnect (not a pun) between the actual battery arrangements (radius) in the tube, and the contact surface (brass ring) on the driver. They don’t really match do they ? Actually hardly at all (brass ring too narrow, cell tops (particularly when solder-blobbed) too far apart. Even with BG “wide flat button tops” they only touch the outer periphery of the brass ring by maybe 1.5mm, judged by witness marks. Solder blobbed things only just touch the very outer edge and maybe could be a bit perilously close to the two driver screws, in the limit. And the battery tube only just contacts the driver PCB at the outermost edge,by less than a mm, after a bit of adjustment, at least in mine.
Just saying, it is what it is, it does seem to work well, regardless.
Facts: diameter of brass ring outer edge 31mm. Distance between centre of cell positive contacts in situ in tube, at least 29mm or more, depending on slimness of cells (I measured 32mm with mine, and some older slim cells), so solder blobs will be riding on the edge of the brass ring (they do, it cuts into them) or “button tops” may ride over the brass ring, by a rather small overlap (they do, and the witness marks show how little contact there is)
I dont understand all this hand measures and etc. Since Miller had shared 3d model files with pdf drawings, you can easily check any dimensions.
Centers of cell holes are laying on 27mm diameter. If hole is 19mm and cell is 18mm, we have 1mm gap to the both inside and outside directions. In my experience cells always go outside, so lets say that centers of non-protected cells are laying on 28mm diameter.
Yes, this is just 1.5mm overlap, but dont forget to add half of button width to this measurement. I.e. with 8mm button top you actualy have 8/2+1.5=5.5mm overlap.
I think head with driver place, and battery tube have ideal central alignment, the only problems may be caused by bad driver ring alignment. Both inner and outer diameters of ring dont match driver pcb mask, that why most driver ring have 1-2mm offset.
