petemer
(petemer)
December 13, 2017, 6:33pm
586
HaikeLite MT03 II Devourer XHP70.2 2SPS New Driver 12000LM High Power LED Flashlight
Use coupon code 90656f to lower the price from $119 to $95 .
3x Cree XHP70.2
max 12000 lm
N4 Cool white or N2 Neutral white tint options
black or silver/white finish options
10 lm lowest setting
LED power indicator (lighted switch)
copper DTP emitter board
Ultra Clear double side AR coated glass lens
» Jump to First post quick links/deals list «
petemer
(petemer)
December 13, 2017, 10:58pm
587
Jetbeam TH15 XHP E2 1450Lumens Ultra-High Performance Tactical Outdoor LED Flashlight
Use coupon code JTTH15S to lower the price from $99.99 to $66.99 (-$33.00 )
Cree XHP35 E2
Jetbeam 2600mAh micro USB rechargeable 18650 battery included (along with holster, clip, tactical ring, 2 spare orings, lanyard and spare rubber cap)
max 1300lm ANSI FL1 (3 min turbo step down + 1.1h high 900lm)
dual switch (side click + tailcap switch)
power indicator LED in side switch
two operation modes (outdoor + tactical) with multiple output levels
min 10 lm (140h using 3500mAh battery)
228 meters (748 ft.) range
one touch strobe hidden in outdoor mode
momentary on
patented Jetbeam “triple tail” switch for easy operation with gloves
stainless clip for EDC
18650 or 2x CR123 power source
constant current LED driver
compatible with remote switch(sold separately)
petemer
(petemer)
December 14, 2017, 12:03pm
588
petemer
(petemer)
December 14, 2017, 12:23pm
589
Eagle Eye X7R XP-L V6 1000Lumens 5Modes USB Rechargeable LED Flashlight 18650/26650
Use coupon code X7RSD to lower the price to $21.60 (–28% ).
Cool White (1A 6500-7000K) and Neutral White (3A 5000-5500K) versions available.
petemer
(petemer)
December 14, 2017, 12:54pm
590
1PCS GETEED 3.7v 4800mAh 35A High Power 21700 20700 Rechargeable Li-ion Battery
This is probably first widely available 21700 li-ion cell. Use coupon code ET217SD to lower the price to $9.68 (–12% )
Judging from 9.5A discharge plot (below) this cell is well suited to high power mods:
petemer
(petemer)
December 14, 2017, 1:31pm
591
ADEASKA SQ2 Intelligent LCD Display USB Rapid Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd Battery
Use coupon code ADSQ2S to lower the price to $11.69 (–30% )
0.5A/1A charge current for li-ion cells
0.5A charge current for Ni-Mh/Ni-Cd cells
standard microUSB power input (DC5V/2A)
USB output (power bank function)
realtime voltage monitoring
battery capacity, time and current display
refresh function for over-discharged cells
over discharge protection for USB power bank function (3V +/- 0.2V)
temperature monitoring
reverse polarity protection
2 years warranty
petemer
(petemer)
December 14, 2017, 1:36pm
592
ADEASKA SQ4 Intelligent LCD Display USB Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd/LiFePO4 Battery
Use coupon code ADASQ4 to lower the price form $39.99 to $26.79 (-$13.20/-33% )
0.5A/1.0A/2.0A charge current for li-ion cells
ability to charge 4 26650/32650/D size batteries at the same time
6A max output (all slots combined )
USB output (power bank function) with 2.1A output
power bank works with cells in any slots
internal resistance measuring
battery capacity, time and current display for each slot
2 years warranty
petemer
(petemer)
December 14, 2017, 1:55pm
593
Folomov A4 LCD Display High Current Quick Charge Intelligent Battery Charger 4Slots
Use coupon code FVA4SD to lower the price from $39.95 to $33.96 (-$5.99 )
250mA/500mA/1000mA/2000mA/3000mA charging current (3A only in two outermost slots)
compatible with Li-ion/LiFePo4/Ni-Mh/Ni-Cd
0V Activation Feature
high contrast negative STN LCD display (light letters on black background)
realtime voltage/current/capacity and charge percent display
petemer
(petemer)
December 14, 2017, 8:27pm
594
Astrolux Flashlight Protected Bag Holster For Astrolux S41/S41S/S42/S42S 12.8x3.2cm
Very good quality single 18650 flashlight holster is now for only $1.33 in flash sale.
Fits all Convoy S2/S2+/BLF A6/Astrolux S1/S41/S42 sized lights perfectly. Also good fit for ~90mm blade sized folding pocket knives.
Offer expires on December 21th.
petemer
(petemer)
December 14, 2017, 9:02pm
595
petemer
(petemer)
December 14, 2017, 9:13pm
596
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube
It’s now in flash sale for $2.45 .
Three colors available: black , red and blue .
Offer expires in 4 days and 11 hours.
petemer
(petemer)
December 14, 2017, 10:25pm
598
XANES DL04 1000LM Dual T6 German Standard Bicycle Light COB Front Light 150° Floodlight Phone Charging Power Bank
New multi-function bike light from Xanes is now in preorder for $13.59 (limited to 150pcs), then the price will gradually rise and target price is supposedly set at $20.99.
This is 3 in 1 device (bike light, lantern and power bank) that doesn’t look half bad
It has 2 x 18650 cells built in (total 4000mAh), claims to deliver 1000lm. COB LED on top serves as lantern - there’s foldable hook on the back and two magnets to affix the lamp to any metal surface. On the bottom side standard USB socket is located to charge any USB rechargeable device.
petemer
(petemer)
December 15, 2017, 12:15pm
599
SKILHUNT H03F XM-L2 U4 1200LM Adjustable LED Flashlight Headlamp
Use coupon code SHH03F to lower the price from $57.95(CW)/$58.95(NW) to $38.99 (-$19.96/-$18.96 )
Both cool white and neutral white versions available in stock.
petemer
(petemer)
December 15, 2017, 12:25pm
600
SKILHUNT H03R XM-L2 1200LM Multi-level EDC LED Flashlight Headlamp
Use coupon code SHH03R to lower the price from $52.90(CW)/$53.90(NW) to $35.99 (-$16.91/-$17.91 )
petemer
(petemer)
December 15, 2017, 9:51pm
601
ReyLight Tool Ti Nichia 219B Titanium 110LM AAA Mini LED Flashlight
Use coupon code YRLTT to get nice 39% discount (-$23.38 ).
The difference from factory Lumintop Tool Ti is the custom Rey driver. It has Low -> Medium -> High mode order and better efficiency (stock Lumintop driver is M>L>H).
petemer
(petemer)
December 15, 2017, 10:30pm
602
LUMINTOP Tool AA XP-L HD 550LM 3Modes Portable Magnet Mini LED Flashlight AA/14500
The flashlight is in VIP promotion right now and BG points can be used to further lower the price:
VIP0/1
VIP2
VIP3
VIP4
VIP5
basic VIP Price
$18.50
$17.50
$17.50
$16.50
$16.50
with BG points
$15.73
$14.70
$14.53
$13.53
$13.20
Package contains both click and magnet tailcap as well as GITD silicone diffuser any lanyard.
petemer
(petemer)
December 16, 2017, 11:01pm
603
Astrolux S2 XPL-HI 1400LM EDC LED Flashlight 18650
It’s now in flash sale for $23.95
This is exactly BLF X6 but with different logo (same BLF conceived FET+1x AMC driver with bistro software).
Offer expires in 2 days and 10 hours.
petemer
(petemer)
December 18, 2017, 1:14pm
604
Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650
It’s now in promo sale until Dec 21st for $19.95
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
petemer
(petemer)
December 18, 2017, 1:21pm
605
XANES SFL02 600LM T6 Smart Induction Bicycle Light IPX4 USB Rechargeable 80° Large Floodlight
It’s now in promo sale for $7.99 until Dec 25th
Light output is claimed to be 600lm in high mode (3,5h runtime), 4 modes in total (high, med 300lm, flash, slow flash) and is equipped with light sensor for auto operation(can be enabled/disabled). Reviews are quite good as well.
