Joson has problems to connect to BLF, so if you need to ask him something, have contact through Gearbest message service
That’s what I did (on Ali) before ordering.
This guy is awesome and gives always a pleasant answer
Yes, I ordered yesterday a 4000K Nichia 219C without strobe-sos.
Waiting… waiting… Xmas will not help shipping
Postman gave me the parcel today : E2L Light Gray 219C-4000K without strobe/SOS
Great product, great beam, just what i wanted :+1: .
But when I tried to mesure stepdown/runtime in High mode, 10mn after ON : the light began flash/strobe like for “low battery” indicator, but battery was full, the flashlight was very hot… is it a thermal protection ?
Is it normal not to be able using the E2L on Hight more than 10mn ?
A tube style 18650 flashlight like the S2+ can sustain about 600-800 lumen (or 2000mA) without functionally damage, I even runtime-tested a S2+ at 3A/800lumen and it got 90 degreesC eventually but did not fail, but it would burn your hand. A E2L has some slight finning near the led so it should be able to handle a tiny bit more output but still the limit is probably still close to that of the S2+. The E2L if I’m right comes with a 6x7135 driver, so 2100mA, that should by just be sustainable, but I can imagine that Jaxman has build in a thermal stepdown that kicks in at lower temperature than 90 degC to prevent burning your hands.
I have an XP-G2 E2L that runs just fine for over 10 min. You might need to check out your battery. Light should run for 90ish min on high with a 3500mAh NCR18650GA. It will get very hot running sustained for that long though. Nichia 219’s do get hotter than the XP-G2.
:person_facepalming: I wrote “full” battery, but in reality it’s a new one (never used, never charged… still waiting my charger) I expectd new battery were full… :innocent: (n00b error)
For the same Amperage or for the same amount of lumens ?
I think it’s because the Nichia has a lower VF than Cree, so it draws more amps causing the LED to get a bit hotter. It seems if you want a higher CRI like the Nichia offerings, you’ll have to give up some lumens and get a little more heat.
The lower the kelvin LED, the lesser the lumens. To make a NW and WW led like the Nichia, requires darker or additional phosphor. Because of this thicker blanket/darker phosphor covering the blue LED it lowers the lumens vs a CW LED with less/lighter colored phosphor.
You mean “blink” for low voltage protection ?
No, on the Convoy with 3-5 driver, what I understand is that at startup in Low mode, after a few seconds, light blinks once (and at this moment you can begin group switch procedure) Maybe I’m wrong…
