✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Yunmai Y3 T6 5Mode 1000LM OP Reflector 18650 EDC LED Flashlight
It’s now in flash sale for only $2.79 !
Offer expires in 7 days and 9 hours.
Keep in mind that the LED is probably not genuine Cree but some Latticebright or other clone. You get what you pay for.
But if you need some potentially disposable 18650 flashlight - this might be good enough. See reviews @banggood product page - there are some pictures.
» Jump to First post quick links/deals list «
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
It’s now in flash sale for only $35.95
Offer expires in 6 days and 10 hours.
To get maximum light output and runtime from this light you should use high drain 18650 battery with additional tube available here:
Astrolux S41S/S42S Flashlight 18650 Extension Tube Body Tube for $9.00 or with using BG points for:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$7.65
$7.56
$7.47
$7.38
$7.20
CPFItalian-5ANNI A01 Copper Nichia 219B  102LM AAA Mini Waterproof Keychain EDC LED Flashlight
Use coupon code 808b65 to lower the price to only $8.51 !!! ($28.99)
This is clearance price! Once it’s gone it won’t be available again.
Offer is valid until December 31st.
Astrolux M02 XP-G2/XP-G3/Nichia 219C 100LM USB Mini LED Flashlight
Use coupon code f8770f to drop the price to only $7.49 ($29.95)
Original Xiaomi MiJIA LED Smart Infrared Human Body Motion Sensor Dimmable Night Light For Home
It’s now in flash sale for only $8.99 ($25.19)
Offer is valid until January 8th.
Original Xiaomi Mijia LED Smart Bluetooth WiFi Control Bedside Light Sunrise Sunset Simulation
Use coupon code XMLED77 to lower the price to $45.64.
Lowest price to date (-US$9.35).
This is second (upgraded) version of Xiaomi bedside lamp. It now uses RGBW LEDs - White ones are Osram LEDs with CRI up to 95.
Second version has gold colored base and now it can communicate also via Wifi (first version was Bluetooth only) and can be paired with MI Home and controlled via voice commands and automatic events (for example light color can indicate room temperature etc.)
  • 10W power
  • adjustable CCT: 1700K - 6500K
  • dimmable
  • color change
  • touch control
  • smartphone control
  • Bluetooth 4.2 BLE
  • Wi-Fi IEEE 802.11 b/g/n 2.4GHz
  • Lamp Input Voltage: 12V, 1A
  • AC power adapter: 100-240V, 50 / 60HZ, 0.5A
  • Size: 100 x 100 x 221mm ( ~4” x 4” x 8.7”)
Klarus G20L XHP70.2 P2 3000Lumens Dual Switch Brightness USB Rechargeable LED Tactical Flashlight
Coupon code is available for $39.58 discount.
» :email:Request via PM here«
  • Cree XHP70.2 P2 LED
  • max 3000lm and 300m range
  • USB rechargeable with 2A fast charging
  • remaining battery capacity indicator (LED inside side switch)
  • 2 switch design (tail click + side click)
  • one touch turbo
  • one touch low
  • Intelligent Temperature Protection System
  • included 5000mAh 26650 battery
  • holster, lanyard ans USB cable included
Astrolux E02 XP-L 900lumens 8modes EDC LED Flashlight 18650
Use coupon code 9975d8 to lower the price to just $9.68
This is clearance price! Last 15 pieces in neutral 3D tint
Coupon is valid until December 31st.
VIOFO A119 V2 Version 1440P 160 Degree Wide Angle Car DVR With Gps Black
Use coupon code fa90e5 to lower the price to $67.19.
This is one of the very best car DVRs with built in GPS in value segment. It has many good reviews, video quality is comparable and sometimes better that brand DVR worth 2x the price - search youtube for sample videos to see for yourself.
It’s also very inconspicuous when mounted on windshield as it lays flat next to mirror mount.
Coupon can not be used on wholesale orders.
It works fine here.
Astrolux K1 XP-G3+365nm UV+Red LED 350LM New Driver USB Stainless Steel Mini LED Keychain
Version with XP-G3 is now in flash sale for $16.95 ($32.95) until January 2nd.
I created another account, that works
Banggood system has some kind of flag for wholesalers to mark their accounts. If that flag is set on your account some limited deals won’t work. You can either create new account yourself or you can contact customer service to clear that flag for you if that’s mistake and you are not wholesaler. Of course that second option takes longer so in case of clearance deals it might be too late…
EKEN H9R Sports Action Camera 4K Ultra HD 2.4G Remote WiFi 170 Degree Wide Angle
This version is equipped with mini remote control. Multiple colors available.
It’s now in preorder for $39.11
Offer is valid for 4 days and 12hours.
30% OFF for whole Lumintop brand
Coupon code: BRANDLMT
Lumintop HL18 XP-L HD 950Lumens Headlamp USB Rechargeable Magnetic Tail Mini LED Flashlight
Using abovementioned coupon code BRANDLMT price drops to $39.16
Lumzoo EOSLAMP SP11-S XPG2 S4 Mini LED Keychain Flashlight With Tritium Tube
Use coupon code 0fba15 to lower already 40% off price to only $12.23 (original price was $39.99)
According to reviews this light has very high finish quality and it’s equipped with tritium vial (GTLS: Gaseous Tritium Light Source doesn’t need sun exposure to light for ~10 years continuously - after that time it will be twice as dim).
One thing very different from all the other twist AAA/10440 lights is that in order to turn it on you need to loosen the head, tightening the head turns it off.
This design is better for EDC keychain duty as the head won’t get lost because it’s always tightened in off position, also it will not turn on accidentally.
Jetbeam IIM Xp-l Hi 1100LM 18650 Tactical Outdooors LED Flashlight
Use coupon code 1e7eb3 to lower already 40% off price from $47.99 to $24.69 (original price was $79.69)
Limited clearance stock available!
I ordered on of these two weeks ago for $30… oh, well. Should I get a second one? :slight_smile:
petemer, You can ask about good price on BLF Q8 ?
I’m very very very interested (must buy) this flashlight but they price is to high to me.
