Use coupon code 808b65 to lower the price to only $8.51 !!! ($28.99) This is clearance price! Once it’s gone it won’t be available again. Offer is valid until December 31st.
Use coupon code XMLED77 to lower the price to $45.64.
Lowest price to date (-US$9.35).
This is second (upgraded) version of Xiaomi bedside lamp. It now uses RGBW LEDs - White ones are Osram LEDs with CRI up to 95.
Second version has gold colored base and now it can communicate also via Wifi (first version was Bluetooth only) and can be paired with MI Home and controlled via voice commands and automatic events (for example light color can indicate room temperature etc.)
Use coupon code fa90e5 to lower the price to $67.19.
This is one of the very best car DVRs with built in GPS in value segment. It has many good reviews, video quality is comparable and sometimes better that brand DVR worth 2x the price - search youtube for sample videos to see for yourself.
It’s also very inconspicuous when mounted on windshield as it lays flat next to mirror mount.
Banggood system has some kind of flag for wholesalers to mark their accounts. If that flag is set on your account some limited deals won’t work. You can either create new account yourself or you can contact customer service to clear that flag for you if that’s mistake and you are not wholesaler. Of course that second option takes longer so in case of clearance deals it might be too late…
Use coupon code 0fba15 to lower already 40% off price to only $12.23 (original price was $39.99)
According to reviews this light has very high finish quality and it’s equipped with tritium vial (GTLS: Gaseous Tritium Light Source doesn’t need sun exposure to light for ~10 years continuously - after that time it will be twice as dim).
One thing very different from all the other twist AAA/10440 lights is that in order to turn it on you need to loosen the head, tightening the head turns it off.
This design is better for EDC keychain duty as the head won’t get lost because it’s always tightened in off position, also it will not turn on accidentally.
